Topic: [SOLVED] Can i use 0v7670 Arduino UNO codes with Arduno Mega 2560 ? (Read 313 times) previous topic - next topic
mpendwavivi
Hallow there!, i have arduino sketch that suppose to take a picture using 0v7670 camera and store that picture in sd card, and am using arduino UNO. but i would like to use arduino Mega 2560 for some reasons and am thinking only if i can change pin numbers of UNO on the sketch to be Mega pins i can work this out. i need some help about where else i can modify so that my sketch can run on arduino Mega 2650.
here down is the current sketch
Code: [Select]
#include <Wire.h>
#include <SD.h>
int CS_Pin = 10;
void Init_YUV422(){
  WriteOV7670(0x12, 0x00);//COM7
  WriteOV7670(0x8C, 0x00);//RGB444
  WriteOV7670(0x04, 0x00);//COM1
  WriteOV7670(0x40, 0xC0);//COM15
  WriteOV7670(0x14, 0x1A);//COM9
  WriteOV7670(0x3D, 0x40);//COM13
void Init_QVGA(){
  WriteOV7670(0x0C, 0x04);//COM3 - Enable Scaling
  WriteOV7670(0x3E, 0x19);//COM14
  WriteOV7670(0x72, 0x11);//
  WriteOV7670(0x73, 0xF1);//
  WriteOV7670(0x17, 0x16);//HSTART
  WriteOV7670(0x18, 0x04);//HSTOP
  WriteOV7670(0x32, 0xA4);//HREF
  WriteOV7670(0x19, 0x02);//VSTART
  WriteOV7670(0x1A, 0x7A);//VSTOP
  WriteOV7670(0x03, 0x0A);//VREF
void Init_OV7670(){
  //Reset All Register Values
  WriteOV7670(0x12,0x80);
  delay(100);
  WriteOV7670(0x3A, 0x04); //TSLB
  WriteOV7670(0x13, 0xC0); //COM8
  WriteOV7670(0x00, 0x00); //GAIN
  WriteOV7670(0x10, 0x00); //AECH
  WriteOV7670(0x0D, 0x40); //COM4
  WriteOV7670(0x14, 0x18); //COM9
  WriteOV7670(0x24, 0x95); //AEW
  WriteOV7670(0x25, 0x33); //AEB
  WriteOV7670(0x13, 0xC5); //COM8
  WriteOV7670(0x6A, 0x40); //GGAIN
  WriteOV7670(0x01, 0x40); //BLUE
  WriteOV7670(0x02, 0x60); //RED
  WriteOV7670(0x13, 0xC7); //COM8
  WriteOV7670(0x41, 0x08); //COM16
  WriteOV7670(0x15, 0x20); //COM10 - PCLK does not toggle on HBLANK
void WriteOV7670(byte regID, byte regVal){
  // Slave 7-bit address is 0x21.
  // R/W bit set automatically by Wire functions
  // dont write 0x42 or 0x43 for slave address
  Wire.beginTransmission(0x21);
  // Reset all register values
  Wire.write(regID);
  Wire.write(regVal);
  Wire.endTransmission();
  delay(1);
void ReadOV7670(byte regID){
  // Reading from a register is done in two steps
  // Step 1: Write register address to the slave
  // from which data is to be read.
  Wire.beginTransmission(0x21); // 7-bit Slave address
  Wire.write(regID);  // reading from register 0x11
  // Step 2: Read 1 byte from Slave
  Wire.requestFrom(0x21, 1);
  Serial.print("Read request Status:");
  Serial.println(Wire.available());
  Serial.print(regID,HEX);
  Serial.print(":");
  Serial.println(Wire.read(),HEX);
void XCLK_SETUP(void){
  pinMode(9, OUTPUT); //Set pin 9 to output
  //Initialize timer 1
  //WGM13, WGM12, WGM11 & WGM10 bits SET- Fast PWM mode
  //COM1A0 SET- Toggle OC1A on compare match
  TCCR1A = (1 << COM1A0) | (1 << WGM11) | (1 << WGM10);
  //SET CS10 bit for clock select with no prescaling
  TCCR1B = (1 << WGM13) | (1 << WGM12) | (1 << CS10);
  //Output Compare Register 1A(OCR1A) = 0
  //This will lead to a match on every clock cycle
  //Toggle OC1A output pin on every match instance
  //Therefore, the generated waveform will have half
  //the frequency of the driving clock i.e. 8Mhz
  //OC1A pin- PB1 (alternate functn) pin i.e. Arduino pin 9
  OCR1A = 0;
// Two Wire Interface Setup
// Sets the frequency of the SCL line
// Default is 100KHz so we won't use this function
void TWI_SETUP(void){
  //Set prescaler bits in TWI Status Register (TWSR) to 0
  TWSR &= ~3;
  //Set SCL frequency to 100KHz
  //SCLfreq = CPUfreq/(16 + 2(TWBR) - 4^(TWPS))
  //TWBR = 72, TWPS(prescaler) = 0
  TWBR = 72;
void OV7670_PINS(void){
  //Setup Data input pins and Interrupt pins
  //DDRC bits 3:0 = 0 =>  bits configured as Data Inputs
  //DDRC 3:0 - A3,A2,A1,A0
  DDRC &= ~15;//low d0-d3 camera
  //~(0b11111100) = 0b00000011
  //make DDRD 7:2 = 0 => Inputs
  //d7-d4 as data inputs, d3-INT1 is VSYNC and d2-INT0 is PCLK
  DDRD &= ~252;
void QVGA_Image(String title){
  int h,w;
  File dataFile = SD.open(title, FILE_WRITE);
  while (!(PIND & 8));//wait for high
  while ((PIND & 8));//wait for low
    h = 240;
  while (h--){
        w = 320;
       byte dataBuffer[320];
    while (w--){
      while ((PIND & 4));   //wait for low
        dataBuffer[319-w] = (PINC & 15) | (PIND & 240);
      while (!(PIND & 4));  //wait for high
    dataFile.write(dataBuffer,320);
    dataFile.close();
    delay(100);
void setup(){
  noInterrupts(); //Disable all interrupts
  XCLK_SETUP();   //Setup 8MHz clock at pin 11
  OV7670_PINS();  // Setup Data-in and interrupt pins from camera
  TWI_SETUP();    // Setup SCL for 100KHz
  interrupts();
  Wire.begin();
  Init_OV7670();
  Init_QVGA();
  Init_YUV422();
  WriteOV7670(0x11, 0x1F); //Range 00-1F
  noInterrupts();
  pinMode(CS_Pin, OUTPUT);
  SD.begin(CS_Pin);
void loop(){
  QVGA_Image("0.bmp");
  QVGA_Image("1.bmp");
  QVGA_Image("2.bmp");
  QVGA_Image("3.bmp");
  QVGA_Image("4.bmp");
  QVGA_Image("5.bmp");
  QVGA_Image("6.bmp");
  QVGA_Image("7.bmp");
  QVGA_Image("8.bmp");
  while(1);
