Topic: MKR WAN 1300 Voltage range on the Vin entry (Read 539 times) previous topic - next topic
ChristianHor
Hello,
For a project with an MKR WAN 1300 and other components, I would like to use a single 12V power supply. Can this card support 12V on its Vin power input?
The information is a little contradictory regarding the power supply range of this input (link1 , link2)
Thanks in advance !
Christian
MITEL
I do not see contradictions:
Vin: This pin can be used to power the board with a regulated 5V source. If the power is fed through this pin, the USB power source is disconnected. This is the only way you can supply 5v (range is 5V to maximum 6V) to the board not using USB.
Perhaps you misread the description of MKR GSM 1400 in the second link, which has different power specs.
