Topic: optical printer encoder (Read 414 times) previous topic - next topic
SolaireNaz
Feb 16, 2019, 10:59 am Last Edit: Feb 16, 2019, 06:06 pm by SolaireNaz
Hello, i have printer encoder which i need to attach to Arduino Leonardo R3, but i don't know the values of +, GND, RX, TX. Can you help me? Printer: MFC-465CN (https://support.brother.com/g/b/spec.aspx?c=us&lang=en&prod=mfc465cn_all)
Here what i have:
What i need:
Additional:
Thank you.
jremington
What does the encoder actually do, and why do you want to connect it to an Arduino?
Riva
I cannot find reference to a B30 7914 sensor but what makes you think it uses serial?
Looking at the images you poster I would guess that pin 1 (your numbering) is power, pin 2 is ground & pins 3/4 are the equivalent of A & B. I would expect them to be digital outputs that either pull high or low when the gate is interrupted.
SolaireNaz
Ty all, btw Riva your guess is right. I forgott that i can use multimeter to find were is the gnd and +.
