Topic: PC - Arduino comms using Python -- updated (Read 2941 times) previous topic - next topic
Robin2
Feb 16, 2019, 10:32 pm Last Edit: Feb 17, 2019, 11:01 am by Robin2
Back in 2014 I posted this Python - Arduino demo. When I looked at it recently it seemed out of line with my more recent Serial Input Basics - updated which was written 2 years later.
In the following pair of programs the Arduino code is almost identical to the code in the 3rd example in Serial Input Basics and the Python code simply sends a short message to the Arduino and prints the reply it receives.
The Python code works with Python3 and Python2.
Arduino Code
Code: [Select]
// This is very similar to Example 3 - Receive with start- and end-markers
//    in Serial Input Basics   http://forum.arduino.cc/index.php?topic=396450.0
const byte numChars = 64;
char receivedChars[numChars];
boolean newData = false;
byte ledPin = 13;   // the onboard LED
    pinMode(ledPin, OUTPUT);
    digitalWrite(ledPin, HIGH);
    delay(200);
    digitalWrite(ledPin, LOW);
    delay(200);
    Serial.println("<Arduino is ready>");
    recvWithStartEndMarkers();
    replyToPython();
void recvWithStartEndMarkers() {
    static boolean recvInProgress = false;
    static byte ndx = 0;
    char startMarker = '<';
    char endMarker = '>';
    char rc;
    while (Serial.available() > 0 && newData == false) {
        rc = Serial.read();
        if (recvInProgress == true) {
            if (rc != endMarker) {
                receivedChars[ndx] = rc;
                ndx++;
                if (ndx >= numChars) {
                    ndx = numChars - 1;
            else {
                receivedChars[ndx] = '\0'; // terminate the string
                ndx = 0;
                newData = true;
        else if (rc == startMarker) {
            recvInProgress = true;
void replyToPython() {
    if (newData == true) {
        Serial.print("<This just in ... ");
        Serial.print(receivedChars);
        Serial.print("   ");
        Serial.print(millis());
        Serial.print('>');
            // change the state of the LED everytime a reply is sent
        digitalWrite(ledPin, ! digitalRead(ledPin));
        newData = false;
Python code
Code: [Select]
import serial
import time
startMarker = '<'
endMarker = '>'
dataStarted = False
dataBuf = ""
messageComplete = False
    # the functions
def setupSerial(baudRate, serialPortName):
    global  serialPort
    serialPort = serial.Serial(port= serialPortName, baudrate = baudRate, timeout=0, rtscts=True)
    print("Serial port " + serialPortName + " opened  Baudrate " + str(baudRate))
    waitForArduino()
def sendToArduino(stringToSend):
        # this adds the start- and end-markers before sending
    global startMarker, endMarker, serialPort
    stringWithMarkers = (startMarker)
    stringWithMarkers += stringToSend
    stringWithMarkers += (endMarker)
    serialPort.write(stringWithMarkers.encode('utf-8')) # encode needed for Python3
def recvLikeArduino():
    global startMarker, endMarker, serialPort, dataStarted, dataBuf, messageComplete
    if serialPort.inWaiting() > 0 and messageComplete == False:
        x = serialPort.read().decode("utf-8") # decode needed for Python3
        if dataStarted == True:
            if x != endMarker:
                dataBuf = dataBuf + x
            else:
                dataStarted = False
                messageComplete = True
        elif x == startMarker:
            dataBuf = ''
            dataStarted = True
    if (messageComplete == True):
        return dataBuf
    else:
        return "XXX"
def waitForArduino():
    # wait until the Arduino sends 'Arduino is ready' - allows time for Arduino reset
    # it also ensures that any bytes left over from a previous message are discarded
    print("Waiting for Arduino to reset")
    msg = ""
    while msg.find("Arduino is ready") == -1:
        msg = recvLikeArduino()
        if not (msg == 'XXX'):
            print(msg)
    # the program
setupSerial(115200, "/dev/ttyACM0")
count = 0
prevTime = time.time()
while True:
            # check for a reply
    arduinoReply = recvLikeArduino()
    if not (arduinoReply == 'XXX'):
        print ("Time %s  Reply %s" %(time.time(), arduinoReply))
        # send a message at intervals
    if time.time() - prevTime > 1.0:
        sendToArduino("this is a test " + str(count))
        count += 1
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
Robin2
gasper002
Thank you! You saved me a lot of time and nerves
