Topic: accessing SD files (Read 686 times) previous topic - next topic
Nicshep
Feb 16, 2019, 10:52 pm Last Edit: Feb 21, 2019, 11:28 pm by Nicshep
This problem is fixed now
I got a MKR ZERO to play audio files off an sd card and when I upload the code it reads the card just fine after I changed the chipSelect to SDCARD_SS_PIN. my problem is that when I use this code at the end of the setup
if(SD.exists("test.wav")) {
Serial.println("there");
}else {
Serial.println("not there");
not there always shows up even though this showed up a line above it
Files found on the card (name, date and size in bytes):
SYSTEM~1/ 2019-02-15 16:31:38
WPSETT~1.DAT 2019-02-15 16:31:38 12
INDEXE~1 2019-02-15 16:31:42 76
TEST.WAV 2019-02-14 19:44:22 1748958
so I know that the file should exist. I have tried putting "test.wav" as "TEST.wav" and the not there message still shows up. Am I using the wrong code for a MKR or am I doing something very wrong? I have looked all over the internet and can't find any fixes for it. Any suggestion will help.
Juraj
Nicshep
I fixed this problem by using the SdFat library rather than using SD library.
