If I understand correctly you want to output a pulse that is high for 1/2 second when the counter value is a multiple of 100.
Determining when to generate the pulse is fairly easy, just check to see when the counter can be evenly divided by 100. Using integer math, you can use the following test for that:
if ( (counter - ( (counter / 100) * 100 ) ) == 0 )
but an easier method is to use the modulo operator, which will divide by a number, and return only the remainder from the division:
if ( ( counter % 100 ) == 0 )
Once you determine when to generate the pulse, set the output high and start a 1/2 second timer. To use a timer, save the current time given by the millis() function, then test to see when the current time is 500 milliseconds more than the saved time. When you reach that time set the output low again.
There are a couple of other issues that have to be considered with your code. The first is what to do if the counter is very slow, or stops at an exact multiple of 100, because that might cause the output to pulse constantly. To prevent this from happening, you can save the value of the counter, and check to make sure it has changed before setting the output high. The other issue is when you reset the counter. A counter value of 0 is also evenly divisible by 100, and presumably you don't want to pulse the output when you press the reset switch. To prevent this, check to see if the counter equals 0 before setting the output high.
Here is your code modified to generate a 1/2 second pulse on pin 9, see if it will work properly:
#include <LiquidCrystal.h>
LiquidCrystal lcd(2, 3, 4, 5, 6, 7); //Pines arduino to lcd
//-------Pins-----//
int Relay = 13; //Solenoid valve open/close
int start_stop = 8; //Start/Stop button
const int sensor_pulse = 12; //Sensor pulse
int rst_cnt = 10; // Reset counter button
//---------Storage debounce function-----//
boolean currentstart_stop = LOW;
boolean laststart_stop = LOW;
boolean lastsensor_pulse = LOW;
boolean currentsensor_pulse = LOW;
boolean lastrst_cnt = LOW;
boolean currentrst_cnt = LOW;
boolean RelayState = LOW;
int counter = 0;
//------------LED and timer------------//
const byte LEDpin = 9; //LED indicator output pin
unsigned long starttime; //time that counter started
unsigned long duration = 500UL; //duration of timer
int LED_counter = 0;
boolean timer_running = false;
pinMode(Relay, OUTPUT);
pinMode(LEDpin, OUTPUT);
digitalWrite(LEDpin, LOW);
lcd.begin(16, 2);
lcd.setCursor(5, 0);
lcd.print("COUNTER");
lcd.setCursor(0, 1);
lcd.print("PULSES");
//----Debouncing function----//
boolean debounce(boolean last, int pin)
boolean current = digitalRead(pin);
if (last != current)
delay(5);
return current;
currentstart_stop = debounce(laststart_stop, start_stop); //Debounce for Start/Stop Button
currentsensor_pulse = debounce(lastsensor_pulse, sensor_pulse); //Debounce for Sensor pulse Button
currentrst_cnt = debounce(lastrst_cnt, rst_cnt); //Debounce for reset counter Button
//-----Start/Stop toggle function----//
if (currentstart_stop == HIGH && laststart_stop == LOW) {
if (RelayState == HIGH) { //Toggle the state of the Relay
digitalWrite(Relay, LOW);
RelayState = LOW;
else {
digitalWrite(Relay, HIGH);
RelayState = HIGH;
laststart_stop = currentstart_stop;
if (lastsensor_pulse == LOW && currentsensor_pulse == HIGH) {
counter = counter + 1;
lastsensor_pulse = currentsensor_pulse;
lcd.setCursor(7, 1);
lcd.print(counter);
if (RelayState == LOW) { //Reset counter while sistem is not running
if (currentrst_cnt == HIGH && lastrst_cnt == LOW) { //Reset Counter
lcd.setCursor(6, 1); // Clear CNT area
lcd.print(" ");
counter = 0;
lastrst_cnt = currentrst_cnt;
if ((counter % 100 == 0) && (LED_counter != counter)) {
//if counter can be evenly divided by 100
// and LED has not already been turned on for this count
// note: the % divides by 100 and gives the remainder
LED_counter = counter;
if (counter != 0) { //check for counter reset
timer_running = true; //start the LED timer
digitalWrite(LEDpin, HIGH); //turn the LED ON
starttime = millis(); //save the start time for the timer
//if timer is running and LED has been on for the needed duration
if ((timer_running) && (millis() - starttime > duration)) {
timer_running = false; //stop the LED timer
digitalWrite(LEDpin, LOW); //turn the LED OFF
}// end void loop
