Topic: H-bridge Help! (Read 888 times) previous topic - next topic
TECH GEEK
I need a h-bridge for a motor, (say a 2-amp motor when under full load) but I don't know how to make a h-bridge with only NPN's tranistors...
also if the motor uses a max of 2-amps, but likely 250mA to 500mA under a typical amount of load,
what should the NPN trsanistors have as their amp rating if used in an H-bridge setup? (Typical & Absolute Max, Amps)
also can anyone provide me a NPN-Only H-bridge Shematic?
         -Thanks-
As always... Thanks for posting!!!
johnwasser
http://www.placella.com/schematics/h-bridge_NPN-only.png
One of the requirements seems to be that you have a power rail higher than the motor drive voltage.  In the schematic above (found with a Google search for: "NPN Only" H-bridge) the motors are driven with 12v and an 18v supply provides the switching current for the transistors.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
See who has no social life: https://forum.arduino.cc/index.php?action=stats :)
simon.monk
You'll run a lot cooler if you use MOSFETs.
http://www.armory.com/~rstevew/Public/Motors/H-Bridges/Blanchard/
Or, you could just buy a motor shield.
I write books about Arduino and Electronics: http://simonmonk.org
