opps, forgot to mention that in the last post. My computer uses little endian and the teensy 3.6 does as well. So that should all be fine and well there.
I'm concerned about sending ASCII because I do not know the number of characters I will be sending over to the teensy. Will I need to code out something to ensure it is, say 5 characters long or is it read over as a complete package like a string (i.e. '02.55' and '10.75')?
Let me have a play around with ASCII. I've modified my code to ping back the value of the sine wave back to matlab and I have it being graphed there.
updated Arduino Code (likely with errors)
#include <SPI.h> //SPI library for Arduino
#include <math.h>
#include <string.h>
//Teensy 3.6 Constants
uint8_t chipSelectPin = 15;
bool GO = false;
char startMarker = '<';
char endMarker = '>';
const int ArbMem = 50e3;
uint16_t Istim = 0;
uint16_t LD;
uint32_t N;
char SendCode[2];
double ArbHeap[ArbMem] = {};
double freq;
double amp;
SPI.begin();
delay(10);
pinMode (chipSelectPin, OUTPUT);
SPI.beginTransaction(SPISettings(17e6, MSBFIRST, SPI_MODE0));
digitalWrite(chipSelectPin, HIGH);
if (GO) {
UpdateStim();
if (Serial.available() > 0) {
UNOSerialEvent();
void UNOSerialEvent() {
byte temp[8];
ElecPairs[1] = 4;
ElecPairs[0] = 5;
byte rb = Serial.read();
if (rb == startMarker) {
Serial.flush();
for (int c = 0; c < 8; c++) {
temp[c] = Serial.read();
freq = byteToDouble(temp);
// get amplitude value second
amp = byteToDouble(temp);
makeSine(freq, amp);
GO = true;
rb = Serial.read();
void UpdateStim(void) {
double Amp = ArbHeap[Istim];
Serial.write(Amp);
Istim++;
if (Istim >= N) {
Istim = 0;
void makeSine(double Freq, double Amp) {
double Stim;
uint8_t Trim = 0x80;
double tld = 14.25;
uint32_t FreqUpdate = floor(1 / (tld * 1e-6));
uint16_t FreqB = 50;
N = (uint32_t)(FreqUpdate / FreqB);
LD = floor(tld * ((FreqB / Freq) - 1));
for ( int c = 0; c < (int)N; c++) {
Stim = Amp*sin((2.0*PI*((double)c))/(double)N);
ArbHeap[c] = Stim;
double byteToDouble(byte doubleNbyte[8]) {
union {
double Out;
byte In[8];
} U ;
U.In[c] = doubleNbyte[c];
return U.Out;
Matlab
SerialID = serial('COM5','BaudRate',115200);
fopen(SerialID);
fwrite(SerialID,'<','char');
fwrite(SerialID,10.00,'double');
fwrite(SerialID,1.00,'double');
fwrite(SerialID,'>','char');
figure(1)
c = 0;
while(1)
c=c+1;
data(c) = fread(SerialID,1,'double');
plot(c,data(c),'.b')
if c == 1
hold on
end
drawnow;
end
