Topic: LED bike light mod (Read 5275 times) previous topic - next topic
nyg78
I am trying to modify the bike light project found at the bottom of this page: http://www.ladyada.net/learn/arduino/lesson5.html
I want to do two things: 1) I want to add a second push button switch to change the direction of the currently running pattern. For example, if the lights go right to left, pushing the button would make them go from left to right, pushing the button again would set them back to the original direction. 2) I want this to remember what light pattern was displayed when it is turned off and then back on again.
I changed some of the patterns from the original code and will add more which I know how to do, but I need help with the two things above. Would I need a buttonState2 in there for the pattern reverse switch?  Any help is appreciated. Thank you. Here's where I'm at:
Code: [Select]
*  Bike light with pattern reverse button
int potPin = 0;                 // input pin for the pot
int timer = 50;
// you can adjust the numbers below to set the max and min for the speed adjustment
int x = 10;        // sets the max speed (0 = fast) the lower the number the faster it can go
int y = 300;      // sets the min speed (100 = slow) the higher the number the slower it can go
int switchPin = 2;              // pattern select switch is connected to pin 2
int switchPin2 = 3;              // pattern reverse switch is connected to pin 3
int led1Pin = 11;
int led2Pin = 10;
int led3Pin = 9;
int led4Pin = 8;
int led5Pin = 7;
int val;                        // variable for reading the pin status
int val2;                       // variable for reading the delayed status
int buttonState;                // variable to hold the button state
int lightMode = 0;              // What mode is the light in?
  pinMode(switchPin, INPUT);    // Set the switch pin as input
  pinMode(switchPin2, INPUT);   // set the 2nd switch as input
  pinMode(led1Pin, OUTPUT);
  pinMode(led2Pin, OUTPUT);
  pinMode(led3Pin, OUTPUT);
  pinMode(led4Pin, OUTPUT);
  pinMode(led5Pin, OUTPUT);
  Serial.begin(9600);           // Set up serial communication at 9600bps
  buttonState = digitalRead(switchPin);   // read the initial state
void loop(){
  val = digitalRead(switchPin);      // read input value and store it in val
  delay(10);                         // 10 milliseconds is a good amount of time
    timer = analogRead(0);               // reads the pot and sets the timer to the value
    timer = map(timer, 0, 1023, x, y);   // maps the timer value to the max and min values set above with x and y
  val2 = digitalRead(switchPin);     // read the input again to check for bounces
  if (val == val2) {                 // make sure we got 2 consistant readings!
    if (val != buttonState) {          // the button state has changed!
      if (val == LOW) {                // check if the button is pressed
        if (lightMode == 0) {          // if its off
          lightMode = 1;               // alternate blinking!
          if (lightMode == 1) {        // if its alternate blinking
            lightMode = 2;             // wave then come back!
            if (lightMode == 2) {      // if its waving then coming back
              lightMode = 3;           // make it wave!
               if (lightMode == 3) { //  if its waving,
                lightMode = 0;           // turn light off!
    buttonState = val;                 // save the new state in our variable
  // Now do whatever the lightMode indicates
  if (lightMode == 0) { // all-off
    digitalWrite(led1Pin, LOW);
    digitalWrite(led2Pin, LOW);
    digitalWrite(led3Pin, LOW);
    digitalWrite(led4Pin, LOW);
    digitalWrite(led5Pin, LOW);
if (lightMode == 1) { // alternate blinking
    digitalWrite(led1Pin, HIGH);
    digitalWrite(led3Pin, HIGH);
    digitalWrite(led5Pin, HIGH);
    delay(timer);
    digitalWrite(led2Pin, HIGH);
    digitalWrite(led4Pin, HIGH);
    delay(timer);
if (lightMode == 2)  { // "wave" then come back
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
  if (lightMode == 3)  { // "wave"
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
nyg78
Any suggestions how to do this?
nyg78
Still haven't figured this out.  Any new people around that can help?  I'm sure it can be done, just don't know how to do it!  Thank you.
Magician
Add some code to work with second button (on pin #3):
Code: [Select]
int val_rev;                        // variable for reading the pin status
int val2_rev;                       // variable for reading the delayed status
int buttonState_rev;
Then in the beginning of main loop you will have to check the status of second "reverse" button:
Code: [Select]
  val_rev = digitalRead(switchPin2);      //REVERSE read input value and store it in val
  val2_rev = digitalRead(switchPin2);     // read the input again to check for bounces
  if (val_rev == val2_rev) {                 // make sure we got 2 consistant readings!
    buttonState_rev = val_rev;                 // save the new state in our variable
And last thing is reverse lighting pattern depends on buttonState_rev, I'll show for light_mode 2 , but you can re-work others similar:
Code: [Select]
if (lightMode == 2) { // blinking
  if ( buttonState_rev == LOW ) {
    delay(100);
    delay(100);
  else  {
    delay(100);
    delay(100);
To store status of the pattern when power is switch off, you have to study how to store variable in EEPROM . In playground, AFAIR, some example code to work with EEPROM
nyg78
I've been working at it but can't get it to work.  I changed some of the original, so from this point this is the code I will be using.  The button to change the pattern works and the pot works, just not button 2 to reverse the pattern.  In the code I only changed the first mode (lightMode 0) to do the reverse, I realize the others are unchanged but want to make sure the button works first, which right now it doesn't.  Here's where I'm at:
Code: [Select]
*  bike light with pattern reverse button & pot
int timer = 50;      // you can adjust the numbers below to set the max and min for the speed adjustment
int switchPin = 2;              // switch is connected to pin 2
int switchPin2 = 13;             // switch to reverse pattern is connected to pin 13
int led1Pin = 11;
int led2Pin = 10;
int led3Pin = 9;
int led4Pin = 8;
int led5Pin = 7;
int led6Pin = 6;
int led7Pin = 5;
int led8Pin = 4;
  pinMode(led6Pin, OUTPUT);
  pinMode(led7Pin, OUTPUT);
  pinMode(led8Pin, OUTPUT);
void loop(){
    timer = map(timer, 0, 1023, x, y);   // maps the timer value to the max and min vaues set above with x and y
        if (lightMode == 0) {          // if its left to right
          lightMode = 1;               // chase left to right then back!
          if (lightMode == 1) {        // if its left to right then back
            lightMode = 2;             // double left to right!
            if (lightMode == 2) {      // if its double left to right
              lightMode = 3;           // all off
              if (lightMode == 3) {    // if its all off
                lightMode = 0;
  if (lightMode == 0)  { // single left to right
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    digitalWrite(led6Pin, HIGH);
    delay(timer);
    digitalWrite(led6Pin, LOW);
    digitalWrite(led7Pin, HIGH);
    delay(timer);
    digitalWrite(led7Pin, LOW);
    digitalWrite(led8Pin, HIGH);
    delay(timer);
    digitalWrite(led8Pin, LOW);
  else  { //single right to left
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
if (lightMode == 1)  { // single light left to right then back
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
  if (lightMode == 2)  { // double lights left to right
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
    delay(timer);
  if (lightMode == 3) { // all off
Magician
Why did you change pin #3 to pin #13?
I don't think pin #13 as input is a good idea, it wired to on-board led.
And, code isn't checking status of the "reverse" button if it in the middle lighting pattern. I just show  you an idea to start with. Try to test it pressing rev. button (pin #3) for long time, when lighting pattern finished it's subroutine and start again.
To make it more responsive for operator, look in:
http://arduino.cc/en/Reference/AttachInterrupt
And it's second reason to live #3 as reverse input, you can't create interrupt routine with #13.
nyg78
Thanks Magician.  I moved it to pin #3 and now it reverses the pattern if I hold it down, but when I let go, it goes back to the original.  How can I get it to "hold" the pattern until I press the button again?
nyg78
Hmmm didn't work.  I was supposed to replace this:
Code: [Select]
With this, right?
Code: [Select]
if (val_rev == val2_rev && val_rev != buttonState_rev ) {
It still won't "hold" the pattern when I let go of the button.  Any other suggestions?
Magician
Probably, it could be done easier, how you wire your buttons to ground?
If so, try this:
Code: [Select]
if (!val_rev) {                 // make sure we got 2 consistant readings!
   buttonState_rev = !buttonState_rev ;                 // save the new state in our variable
nyg78
Wow, it works!  Thank you very much for your help!
I wire the buttons to ground just like here http://www.ladyada.net/learn/arduino/lesson5.html
Another thing.  When I originally was putting this together, instead of this which I currently have:
Code: [Select]
    delay(timer);
    delay(timer);
I had used this, which seemed to not be so jerky when the pot was turned:
Code: [Select]
    delay(timer);
    delay(timer);
Doing this to every pattern took up a lot of memory.  Do you know a way to make it look smoother as I turn the pot?
Also, sometimes when I push the button to change the pattern, it doesn't work, but if I turn the pot slightly and then push the button it will change the pattern.  Any way to fix this?
I appreciate all of the help you have provided.
Magician
I'd leave analogRead in the beginning, as in original version, and try to smooth out irregularities by averaging:
Code: [Select]
  timer = 0;
for ( int i = 0; i < 10; i++ ) {
    timer += analogRead(0);               // reads the pot and sets the timer to the value
  timer = timer / 10;
nyg78
So put that in the void loop() section under the delay(10)?
Magician
#12
Jul 30, 2011, 02:23 am Last Edit: Jul 30, 2011, 02:28 am by Magician Reason: 1
Yes, like in the post #4.
Quote
And look into attachinterrupt, I advised you earlier, it should fix it.
nyg78
That fixed the smoothing issue.  I going to work on that attachinterrupt.
nyg78
Getting nowhere with this interrupt.  I'm completely lost.
