Topic: MAC OSX 10.13.6 stk500_recv(): programmer is not responding (Read 1 time) previous topic - next topic
jpbsb
Greetings, all.
I can't upload Blink or anything to my brand new Arduino Uno using my Macbook running OSX High Sierra (10.13.6).
Under "tools", board is selected as "Arduino/Genuino Uno" and port is "dev/cu.usbserial-RCBB_3V2BBR".
I've already tried everything under the troubleshooting guide in "http://www.arduino.cc/en/Guide/Troubleshooting#upload", including several reboots and three different USB cables.
Here's the error message I'm getting:
Arduino: 1.8.8 (Mac OS X), Board: "Arduino/Genuino Uno"
Sketch uses 930 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
HELP ME, OBI-WAN, YOU'RE MY ONLY HOPE!
jpbsb
Here's the error message with the "verbose" setting, for more details:
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbserial-RCBB_3V2BBR -b115200 -D -Uflash:w:/var/folders/ss/57pqd8_j6fq9f30q4cxttnl00000gn/T/arduino_build_402107/Blink.ino.hex:i
avrdude: Version 6.3-20171130
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/joaquimprado/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/cu.usbserial-RCBB_3V2BBR
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude done.  Thank you.
woodridgestudi00
Same issue with Win7. I have many Arduino. This seems to randomly happen to them and I can not fix it. I get this and a few other error messages depending on the arduino and how many times I try to upload. I hope there is a solution.
DrAzzy
resp=0x00 indicates you have something that looks like a serial port, but as far as the computer can tell, nothing is connected to it, ie, the arduino is not responding.
Do you get the triple-blink from the LED on the arduino when you try to upload? You should, since the board should be resetting the arduino, and the bootloader will then blink the LED to tell you that the bootloader is running.
ATTinyCore for x4/x5/x61/x7/x8/x41/1634/828/x313 megaTinyCore for the megaavr ATtinies - Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store http://tindie.com/stores/DrAzzy
