Topic: Problem with the combination of writing temperatures to screen and also to SD  (Read 243 times) previous topic - next topic
MARIEKOLDERUP
Hi!
We want to log the temperature at 8 spots. Further, we want to save the data to the SD card and also show it on the screen continuously. When we only include one of the above in the code, it works. Meaning it writes to the SD card when the writing to screen is excluded and it writes to the screen when the SD-writing is excluded. When we include both, the code stops at the SD.begin. We have tried both SDFat and SD libraries as the code shows.
We us these type of components:
Clock: ds3231 at24c32 iic RTC
Screen: 2.8 tft spi 240x320 v1.2
Amplifier: MAX31850K
Level-shifter: BSS138
Green R = 1200 ohm
Yellow R = 1800 ohm
Blue R = 56 ohm
Connections:
Arduino - SD card reader:
D4 - SD_CS;
D11 - SD_MOSI;
D12: SD_MISO;
D13 - SD_CLK.
Arduino - Screen:
3V3 - VCC
GND - GND
D10 → green R →  CS
                  → yellow R → GND
D8 → green R   → RST
                       → yellow R → GND
D13 → green R → CLK
                       → yellow R→ GND
D3 → greenR    → MOSI
                       → yellow R  → GND
D9 → green R   → DC
                       → yellow R → GND
5V → blue R     → LED
D5 → MISO
Clock:
A5    →  SCL
A4    →  SDA
3v3  → VCC
GND → GN
Code:
//Libraries included
#include <Adafruit_ILI9341.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SPITFT.h>
#include <Adafruit_SPITFT_Macros.h>
#include <gfxfont.h>
#include <Sodaq_DS3231.h>
#include <Wire.h>
#include <SPI.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <SD.h>
//#include <SdFat.h>
#define TFT_DC 9
#define TFT_CS 10
#define TFT_RST 8
#define TFT_MISO 5
#define TFT_MOSI 3
#define TFT_CLK 13
#define ONE_WIRE_BUS 2
#define TEMPERATURE_PRECISION 9
//Definitions
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_MOSI, TFT_CLK, TFT_RST, TFT_MISO);
float maxTemperature=0;
float minTemperature=200;
char charMinTemperature[10];
char charMaxTemperature[10];
char timeChar[100];
char dateChar[50];
char temperatureChar[10];
float temperature = 0;
float previousTemperature = 0;
uint32_t old_ts;
String dateString;
int minuteNow=0;
int minutePrevious=0;
const int chipSelect = 4;
//SdFat sd;
//SdFile myFile;
File myFile;
OneWire oneWire(ONE_WIRE_BUS); // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
DallasTemperature sensors(&oneWire);
DeviceAddress insideThermometer; // arrays to hold device addresses
void setup(){
//Setup
  pinMode(4, OUTPUT);
  digitalWrite(4, HIGH);
  tft.begin();
  tft.setRotation(0);
  tft.fillScreen(ILI9341_BLACK);
  Wire.begin();
  rtc.begin();
  sensors.begin();
//HEADLINES
//printText(char *text, uint16_t color, int x, int y,int textSize)
printText("Sensor:", ILI9341_PINK, 1, 75, 5/2);
printText("Value:", ILI9341_YELLOW, tft.width()/2, 75, 5/2);
//Sensors
printText("TEMP 1", ILI9341_WHITE, 1, 100, 2);
printText("TEMP 2", ILI9341_WHITE, 1, 125, 2);
printText("TEMP 3", ILI9341_WHITE, 1, 150, 2);
printText("TEMP 4", ILI9341_WHITE, 1, 175, 2);
printText("TEMP 5", ILI9341_WHITE, 1, 200, 2);
printText("TEMP 6", ILI9341_WHITE, 1, 225, 2);
printText("VOLT 1", ILI9341_WHITE, 1, 250, 2);
printText("VOLT 2", ILI9341_WHITE, 1, 275, 2);
//clock
 //setRTCTime();
// Find Thermometer adresses
  if (!sensors.getAddress(insideThermometer, 0))
  if (!sensors.getAddress(insideThermometer, 1))
  if (!sensors.getAddress(insideThermometer, 2))
  if (!sensors.getAddress(insideThermometer, 3))
  if (!sensors.getAddress(insideThermometer, 4))
  if (!sensors.getAddress(insideThermometer, 5))
  if (!sensors.getAddress(insideThermometer, 6))
  if (!sensors.getAddress(insideThermometer, 7))
  // set the resolution to 9 bit
  sensors.setResolution(insideThermometer, TEMPERATURE_PRECISION);
  sensors.requestTemperatures();
  DateTime now = rtc.now(); //get the current date-time
  uint32_t ts = now.getEpoch();
    if (old_ts == 0 || old_ts != ts) {
  old_ts = ts;
  minuteNow = now.minute();
  if (minuteNow!=minutePrevious){
   // dateString = getDayOfWeek(now.dayOfWeek())+", ";
    dateString = String(now.date())+"/"+String(now.month());
    dateString= dateString+"/"+ String(now.year());
    minutePrevious = minuteNow;
    String hours = String(now.hour());
    if(now.minute()<10)
      hours = hours+":0"+String(now.minute());
    }else
      hours = hours+":"+String(now.minute());
    hours.toCharArray(timeChar,100);
    tft.fillRect(00,00,tft.width(),70,ILI9341_BLACK);
    printText(timeChar, ILI9341_RED,90,25,2);
    dateString.toCharArray(dateChar,50);
    printText(dateChar, ILI9341_GREEN,65,1,2);
//Initializing SD card:
 //SD.begin(4);
 // myFile.println("testing 1, 2, 3.");
 //  myFile.close();
 //SD.begin(4);
 myFile= SD.open("TEST.txt", FILE_WRITE);
  for (uint8_t i = 0; i < 8; i++)
 myFile.print(sensors.getTempCByIndex(i));
myFile.close();
tft.fillRect(tft.width()/2,100,90,90,ILI9341_BLACK);
         tft.setCursor(tft.width()/2,100);
    tft.setTextSize(2);
    tft.setTextColor(ILI9341_WHITE);
    tft.print(sensors.getTempCByIndex(0));
    tft.setCursor(tft.width()/2+70,100);
    tft.print("C");
    tft.fillRect(tft.width()/2,125,90,90,ILI9341_BLACK);
         tft.setCursor(tft.width()/2,125);
    tft.setTextSize(2);
    tft.print(sensors.getTempCByIndex(1));
     tft.setCursor(tft.width()/2+70,125);
    tft.print("C");
    tft.fillRect(tft.width()/2,150,90,90,ILI9341_BLACK);
         tft.setCursor(tft.width()/2,150);
    tft.setTextSize(2);
    tft.print(sensors.getTempCByIndex(2));
 tft.setCursor(tft.width()/2+70,150);
    tft.print("C");
void printText(char *text, uint16_t color, int x, int y,int textSize)
  tft.setCursor(x, y);
  tft.setTextColor(color);
  tft.setTextSize(textSize);
  tft.setTextWrap(true);
  tft.print(text);
void setRTCTime()
  DateTime dt(2019, 2, 20, 23, 59, 0, 3); // Year, Month, Day, Hour, Minutes, Seconds, Day of Week
  rtc.setDateTime(dt); //Adjust date-time as defined 'dt' above
PaulS
Code: [Select]
If one of the sensors doesn't work, set the resolution of the but to 9 bits. I can't imagine how that is a useful thing to do.
Code: [Select]
char timeChar[100];
char dateChar[50];
Are these array sizes even remotely close to reasonable?
A schematic is definitely in order. Your description of what is connected to which pins is far too confusing. You appear to be doing software SPI and hardware SPI at the same time, but trying to share pins between the hardware and software SPI. You can NOT do that. If you are going to do software SPI, you MUST choose 4 pins that are NOT part of the hardware SPI setup.
Pin 10 should be defined as an OUTPUT pin, to make the Arduino an SPI master.
