Topic: issue uploading to breadboard ATMEGA4809 via uno (Read 1 time) previous topic - next topic
samyoue
Feb 23, 2019, 07:07 pm Last Edit: Mar 03, 2019, 02:00 am by samyoue
I'm trying to build my first arduino from components on a breadboard (First time building arduino on a breadboard, figured I'd start easy by using a 4809 ::) ).
I have the ATMEGA4809 chip on my breadboard via a tqfp adapter and attached all necessary basic elements such as 16mhz clock and capacitors, power etc.
I have an uno R3 board hooked up via mosi/miso/sclk/d10 to mosi/miso/sclk/reset and uploaded the ISP sketch to the uno.
I've downloaded the 'megaAVR boards' into the board manager and have selected the arduino uno wifi as my board with the 'Registers emulation:' option set to 'None (ATMEGA4809)'
I have my uno connected via usb and 4809 breadboard connected via dupont wires as mentioned above
I have selected 'arduino as ISP' in 'Programmer:' option
However when I click burn bootloader it comes up with:
Code: [Select]
Arduino: 1.8.8 (Windows Store 1.8.19.0) (Windows 10), Board: "Arduino Uno WiFi Rev2, None (ATMEGA4809)"
Please select a programmer from Tools->Programmer menu
option enabled in File -> Preferences.
before I downloaded the 'megaAVR boards' I was getting 'invalid device signature' error (ie. further than I am now that I have the correct board definition...  :smiley-eek: )
any help greatly appreciated
Sam
EDIT:
Ive tried a few times using 'arduino Uno' as my board (ie. that of the ISP not the target) and I've got error device signature invalid 0xFFFFFF, but also have got the following:
Code: [Select]
Arduino: 1.8.8 (Windows Store 1.8.19.0) (Windows 10), Board: "Arduino/Genuino Uno"
C:\Users\CeX\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino14/bin/avrdude -CC:\Users\CeX\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino14/etc/avrdude.conf -v -patmega328p -carduino -PCOM8 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3-20171130
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\CeX\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino14/etc/avrdude.conf"
         Using Port                    : COM8
         Using Programmer              : arduino
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Error while burning bootloader.
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x00007f
avrdude: Expected signature for ATmega328P is 1E 95 0F
         Double check chip, or use -F to override this check.
avrdude done.  Thank you.
and also received device signatures of ff0000, 0000ff as well, not sure if its relevant or not...
Juraj
you are funny. 4809 doesn't use ISP for programming and doesn't use a bootloader.
it uses UPDI.
You can't write an Arduino sketch if you didn't learn programming. Not the language, but the concepts of programming - algorithms and data types.
westfw
4809 COULD use a bootloader, but the Uno WiFi 2 Arduino board that has a 4809 doesn't use one (it has an on-board programmer instead), and thus Arduino doesn't have one.
It's on the Optiboot "issues" list, but ... it's complicated.  One of the major changes in the 4809 chip is the way the bootloader works :-(
samyoue
OK didn't realise that (like I said, first voyage into this...). That explains my problems thank you.
After some research, I believe I can use my Uno to program my 4809 by using this.
Am I correct in assuming that if I use this method I can upload a sketch to the 4809 through the Uno using "atmel jtagice3 (jtag mode)" in the programmer option of Arduino IDE?
(WARNING: SUPER N00B QUESTION!) if there is no bootloader on the 4809, would the sketch auto run on powerup?
Thanks again guys
Sam
westfw
Quote
Yes.  On the UW2, the programmer chip will have very complete control over the chip, and won't hold up execution unless it's getting explicit "program" or "debug" instructions on the USB port.
On a bare 4809 (well, in both cases, actually), the sketch is the only thing on the chip, and it will start after reset.
samyoue
Thats great thank you, can anyone confirm/correct this for me please?
Thanks again everyone
Sam
samyoue
OK so I tried it out and experimented and googled and I'm completely at a loss now...
I followed this tutorial
https://github.com/ElTangas/jtag2updi
and couldn't get much joy.
Followed this tutorial afterwards:
https://hackaday.io/project/134831-atmega4809-developing-board-project/log/156750-how-to-setup-arduino-ide-full-support-including-binary-upload-for-my-board
and managed to finally upload a sketch to my 4809 (via my uno with firmware from 1st tutorial)
if I click upload sketch or upload via programmer (with "onboard atmel..." selected as the programmer) then I get successful uploads to my 4809 according to avrdude
Code: [Select]
Sketch uses 1406 bytes (2%) of program storage space. Maximum is 49152 bytes.
Global variables use 28 bytes (0%) of dynamic memory, leaving 6116 bytes for local variables. Maximum is 6144 bytes.
C:\Users\CeX\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino14/bin/avrdude -CC:\Users\CeX\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino14/etc/avrdude.conf -v -patmega4809 -cjtag2updi -Pcom8 -Uflash:w:C:\Users\CeX\AppData\Local\Temp\arduino_build_617903/BlinkWithoutDelay.ino.hex:i -Ufuses:w:C:\Users\CeX\Documents\ArduinoData\packages\arduino\hardware\megaavr\1.6.25/fuses/fuses_4809.bin:r
         Using Port                    : com8
         Using Programmer              : jtag2updi
JTAG ICE mkII sign-on message:
Communications protocol version: 1
M_MCU:
  boot-loader FW version:        1
  firmware version:              6.00
  hardware version:              1
S_MCU:
  hardware version:              1
Serial number:                   00:00:00:00:00:00
Device ID:                       JTAGICE mkII
         AVR Part                      : ATmega4809
         Chip Erase delay              : 0 us
         PAGEL                         : P00
         BS2                           : P00
         RETRY pulse                   : SCK
         Timeout                       : 0
         StabDelay                     : 0
         CmdexeDelay                   : 0
         SyncLoops                     : 0
         ByteDelay                     : 0
         PollIndex                     : 0
         PollValue                     : 0x00
         Memory Detail                 :
           prodsig        0     0     0    0 no         61   61      0     0     0 0x00 0x00
           fuses          0     0     0    0 no          9    0      0     0     0 0x00 0x00
           fuse0          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse1          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse2          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse4          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse5          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse6          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse7          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse8          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           lock           0     0     0    0 no          1    0      0     0     0 0x00 0x00
           data           0     0     0    0 no          0    0      0     0     0 0x00 0x00
           usersig        0     0     0    0 no         64   64      0     0     0 0x00 0x00
           flash          0     0     0    0 no      49152  128      0     0     0 0x00 0x00
           eeprom         0     0     0    0 no        256   64      0     0     0 0x00 0x00
         Programmer Type : JTAGMKII_PDI
         Description     : JTAGv2 to UPDI bridge
         M_MCU hardware version: 1
         M_MCU firmware version: 6.00
         S_MCU hardware version: 1
         S_MCU firmware version: 6.00
         Vtarget         : 5.0 V
avrdude: jtagmkII_initialize(): Cannot locate "flash" and "boot" memories in description
Reading | ################################################## | 100% 0.03s
avrdude: Device signature = 0x1e9651 (probably m4809)
avrdude: NOTE: Programmer supports page erase for Xmega devices.
         Each page will be erased before programming it, but no chip erase is performed.
         To disable page erases, specify the -D option; for a chip-erase, use the -e option.
avrdude: reading input file "C:\Users\CeX\AppData\Local\Temp\arduino_build_617903/BlinkWithoutDelay.ino.hex"
avrdude: writing flash (1406 bytes):
Writing | ################################################## | 100% 0.42s
avrdude: 1406 bytes of flash written
avrdude: verifying flash memory against C:\Users\CeX\AppData\Local\Temp\arduino_build_617903/BlinkWithoutDelay.ino.hex:
avrdude: load data flash data from input file C:\Users\CeX\AppData\Local\Temp\arduino_build_617903/BlinkWithoutDelay.ino.hex:
avrdude: input file C:\Users\CeX\AppData\Local\Temp\arduino_build_617903/BlinkWithoutDelay.ino.hex contains 1406 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.27s
avrdude: verifying ...
avrdude: 1406 bytes of flash verified
avrdude: reading input file "C:\Users\CeX\Documents\ArduinoData\packages\arduino\hardware\megaavr\1.6.25/fuses/fuses_4809.bin"
avrdude: writing fuses (9 bytes):
Writing | ################################################## | 100% 0.07s
avrdude: 9 bytes of fuses written
avrdude: verifying fuses memory against C:\Users\CeX\Documents\ArduinoData\packages\arduino\hardware\megaavr\1.6.25/fuses/fuses_4809.bin:
avrdude: load data fuses data from input file C:\Users\CeX\Documents\ArduinoData\packages\arduino\hardware\megaavr\1.6.25/fuses/fuses_4809.bin:
avrdude: input file C:\Users\CeX\Documents\ArduinoData\packages\arduino\hardware\megaavr\1.6.25/fuses/fuses_4809.bin contains 9 bytes
avrdude: reading on-chip fuses data:
Reading | ################################################## | 100% 0.05s
avrdude: 9 bytes of fuses verified
and due to this line:
Code: [Select]
 it is definitely uploading to the 4809 and not the uno...
yet no blinky blinky :(
samyoue
I've checked the LED connections etc (if i take the dupont lead connected to the portD0 pin on the 4809 and touch it to the 5v rail, the LED lights up)
I've also tried manual upload of this hex file, https://github.com/szczys/had_AVRtut_2 which is referenced to by this tutorial: https://hackaday.com/2010/10/25/avr-programming-02-the-hardware/ by using avrdude directly and I get the same 'result'
Code: [Select]
C:\Users\CeX\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino14\bin> .\avrdude -c jtag2updi -P com8
 -p m4809 -U flash:w:main.hex
avrdude.exe: jtagmkII_initialize(): Cannot locate "flash" and "boot" memories in description
avrdude.exe: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.10s
avrdude.exe: Device signature = 0x1e9651 (probably m4809)
avrdude.exe: NOTE: Programmer supports page erase for Xmega devices.
avrdude.exe: reading input file "main.hex"
avrdude.exe: input file main.hex auto detected as Intel Hex
avrdude.exe: writing flash (258 bytes):
Writing | ################################################## | 100% 0.37s
avrdude.exe: 258 bytes of flash written
avrdude.exe: verifying flash memory against main.hex:
avrdude.exe: load data flash data from input file main.hex:
avrdude.exe: input file main.hex contains 258 bytes
avrdude.exe: reading on-chip flash data:
Reading | ################################################## | 100% 0.29s
avrdude.exe: verifying ...
avrdude.exe: 258 bytes of flash verified
avrdude.exe done.  Thank you.
 with again no LED activity on the 4809.
Its almost like the 4809 is accepting uploads but not actually executing the program...
Note when using arduino IDE, I also tried changing ledPin to 0 and also 1 to see if it was a pin issue but again nothing.
If I hold the reset button on the 4809 board while uploading the upload fails (which is correct)
I've tried resetting my 4809 afterwards which has no effect
please help me, any pointers/ideas/solutions welcomed
Thanks
Sam
(had to split into 2 posts as exceeded the post length limit)
westfw
What (chip) pin is your LED connected to, and what (arduino board) pin is your sketch manipulating?
Chances are that they don't match.
Are you using the Uno-WiFi2 board type, or have you made your own board?
samyoue
In the sketch I've tried builtin, 0 and 1, on the chip I've tried port D pin 0 and port D pin 1, Port C pin 0, Port B pin 0 and port A pin 0 on all the sketch variations...
I've built it on a breadboard using a tqfp breadboard adapter
Sam
pert
samyoue
OK I'll try it again on builtin and pd6 tonight
Ahhh I've just found the pinout spreadsheet for the 4809 on here, that explains it - I mistakenly thought it would follow the same pattern as the normal uno pinouts Re ports and Arduino pins...
Thank you all!
Sam
samyoue
Just to confirm, finally all working! Thank you!
now onto the rest of the project!
Sam
pert
Way cool! It's a wonderful feeling to see that LED start blinking.
A_neves
@samyoue,
I am trying to program my atmega 4809 with arduino uno using ELTangas software (https://github.com/ElTangas/jtag2updi).
But I can not program the atmega4809. I am getting
Code: [Select]
avrdude.exe : jtagmkII_getsync(): sign-on command: status -1
Could you tell me how do you get this working?
Thank you!
