Topic: Car Heads Up Display (Read 12028 times) previous topic - next topic
Power_Broker
#30
Feb 08, 2020, 06:07 am Last Edit: Feb 08, 2020, 06:07 am by Power_Broker
Here are the details/gerber files for the updated PCB design:
"The desire that guides me in all I do is the desire to harness the forces of nature to the service of mankind."
   - Nikola Tesla
GaryP
Idea of the circuit is nice, but that limits us using mph only, with km/h we would need three digits.
Well, the core of your design probably is easy to change to use other displaying methods.
Cheers,
kari
The only law for me; Ohms Law: U=R*I       P=U*I
Note to self: "Damn! Why don't you just fix it!!!"
Power_Broker
True, I don't plan on going over 99mph or driving in kph, but it shouldn't bee too hard to add a new LED display. If you use an ESP32, you might run out of pins, but then again, maybe not.
Also, I tested some recent updates to ELMduino and verified everything still works! Looks like max throughput of the ELM327 is 13 total queries per second. This means, if I'm querying for both speed and rpm, I should expect a sample rate of about 6.5Hz - not bad! :D
I also was able to setup a *very* simple Access Point webserver with dynamic content (AJAX).
Currently printing the new HUD enclosure - pics soon!
   - Nikola Tesla
Power_Broker
#33
Feb 18, 2020, 01:16 am Last Edit: Feb 18, 2020, 01:17 am by Power_Broker
Turns out that you can't use all pins on the ESP32 for digital IO. Because of that, I need to add another MCU to the board for LED driving and SPI communication. I decided to pair up the Teensy I had on the old HUD PCB with the ESP on the new PCB.
Attached are the pics and gerber files
   - Nikola Tesla
Power_Broker
And attached are the .obj files for 3D printing
   - Nikola Tesla
jimLee
If you're really getting fussy about digits, units etc. Just replace it with an OLED and have at it showing whatever you like.
-jim lee
PNW Ardiuno & Maker club
1012 9Th Street, Anacortes, WA 98221 (Around the back of building)
Power_Broker
True, but is an OLED screen as bright as LEDs at full power? I'm concerned I won't be able to see the OLED screen on a sunny day
   - Nikola Tesla
GaryP
OLEDs are typically small, so LED displays are nicer. Of course there is plenty of substitutes
for this design, so everyone should find suitable for them purposes.
I like to use TM1638s.
Cheers,
Kari
jimLee
It wouldn't be as bright. And, sadly, OLEDs have limited lifespan. But, if they turned out to be bright enough, it could look really cool for awhile. Kinda' like the ones on the Chevy Camaros, where you get a color tach seemingly floating over the hood of the car.
-jim lee
Power_Broker
#39
Mar 04, 2020, 10:41 pm Last Edit: Mar 04, 2020, 10:52 pm by Power_Broker
Update: Because I didn't realize some of the LED control wires were routed to non-digital pins on the Teensy (DAC0 and DAC1) as well as one LED control wire to D13, I had to revise the PCB design and order another set. The new PCBs should get here tomorrow or Friday.
I also added the ability to connect a color OLED screen to the PCB that will be controlled via the Teensy.
Attached are the PCB gerber files.
   - Nikola Tesla
Power_Broker
Also, I made some massive improvements in the ELMduino.h library!
Now you can use the library for custom PID queries in addition to standard queries. I also listed all available AT commands in the header.
   - Nikola Tesla
jimLee
I know one person's library may not be useful to anyone else, but.. If you would like a library that supports drawing to your OLED. And other things if you so desire. I have one you could try.
Actually, there's an entire multi-sketch swapping OS in there. But maybe save that for later?
The folder to look at first is LC_Screen
The library folder
I'm currently working on the wiki for all this nonsense.
-jim lee
Power_Broker
Very impressive collection of libraries! I'll be honest, I don't know where to start...
For now I'm only going to display speed, rpm, and ELM327 errors on the OLED. At some point it might be nice to have the capability for a menu system at some point to check/clear car error codes. Does one of you libs support easy menu making?
Currently, though, I plan on checking error codes via the ESP32's access point webserver on my phone/laptop (among other cool things).
   - Nikola Tesla
jimLee
Easy, no.. But the bases are there. You can do a list of things and have them lined up. The place to start is LC_baseTools. Everything is built on them. Even if you use nothing else, they are a really handy set of things to have around for doing Arduino code.
-jim lee
Power_Broker
   - Nikola Tesla
