Topic: Contrast problem on i2c? (Read 1 time) previous topic - next topic
tudorcraft
I want to print something using the A1602 display with I2C shield, but when I print something, everything is white(see attachment).
Here is the code, by the way:
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address, if it's not working try 0x27.
void setup(){
  lcd.begin(16,2);   // iInit the LCD for 16 chars 2 lines
  lcd.backlight();   // Turn on the backligt (try lcd.noBaklight() to turn it off)
  lcd.setCursor(0,0); //First line
  lcd.print("I2C LCD Tutorial");
  lcd.setCursor(0,1); //Second line
  lcd.print("*Ardumotive.com*");
void loop(){
spycatcher2k
Adjust the variable resistor you have on the contrast pin.
Mrs Drew
UK Based PCB Manufacturing - PM for details
I will design & code for you, but I will also charge you (PM me)
Use Google or search this site BEFORE asking!
tudorcraft
Already tried that, it doesn't work. It just changes the brightness.
spycatcher2k
Then check your wiring! or better still, post your wiring diagram here.
Mrs Drew
wolframore
Are you using a 1602 with the backpack?  The blue potentionmeter on the backpack adjusts the contrast.  Have you tried that?  Please include pictures and wiring diagram.
Bad Boys Race Our Young Girls But Violet Generally Wins - Get Some Now :) - ELI ICE man
TheMonkey
#5
Mar 19, 2019, 06:21 pm Last Edit: Mar 19, 2019, 06:22 pm by TheMonkey
Your code says 0X27 and notes say to try 0x27 if not, so you seem to be aware of two addresses, but have you tried 0x3F?
Or maybe you got it working, it's a few weeks old. If you got it working, what was fix?
