Topic: 4 digit display with keypad (Read 612 times) previous topic - next topic
IY3775
Basically, using the 4 digit 7 segment tm1637 module and 4*4 matrix keypad.
I want to be able to type numbers on keypad, and the display will continue showing till 4th number. When I press * or #, it should clear the display. Now with the "A", "B" ,"C", "D" keys, I want a pin to pull high when I press "A" , when I press "B" pull low "A" 's pin and pull high another pin for B (4 Letters like a selector switch, to control a relay).
Could someone type the code for me please?
J-M-L
Quote
type which code?
did you mean invent the code and develop that for you?
Hello - Please do not PM me for help,  others will benefit as well if you post your question publicly on the forums.
Bonjour Pas de messages privés SVP, postez dans le forum directement pour que ça profite à tous
patduino
Hu IY3775,
That's pretty straightforward, but you'll need to work out some of the details.
A few questions for you:
1. What does "displaying until the 4 th number" mean?  Do you want the display to clear or lock in the number?
2. What should the sketch when it receives a 5th digit? It's already displaying 4, should it ignore it or shift the displayed number, i.e., 1234 displays "1234" and pressing 5 displays "2345"?
3. What happens when the 4th digit is entered? Are you comparing it to an expected code or does the number get used in some other way?
4. I assume the A-D buttons work independently from the others and won't intetf with the numeric sequence.
Pat
There are 10 types of people in the world, those who understand binary, and those that don't.
wolframore
Seems pretty straight forward. Key code and relay activation.
Bad Boys Race Our Young Girls But Violet Generally Wins - Get Some Now :) - ELI ICE man
tasmod
They always seem simple till you talk to the user about the real requirements.
