Topic: mkr1000 not detected on mcreate (Read 308 times) previous topic - next topic
gtdixon
I am using mac mojave op sys on firefox with usb connection to mkr1000. Green light on board seems to prove connecttion is good. Cannot detect on create/editor or cloud.
pert
The MKR1000 comes with its pins stuck into some black anti-static foam, which is conductive. You need to remove this foam before you can use the MKR1000.
Make sure the USB cable is fully plugged into the MKR1000 and your computer.
Try using a different USB cable. You might have a damaged, defective, or charge-only USB cable.
gtdixon
Thanks.USB canle was charge-only.
