Topic: Upload problem with Arduino uno and touchshield slide liquuidware (Read 1 time) previous topic - next topic
uno23
Hi, I'm using a arduino UNO with a touchshield slide http://www.liquidware.com/shop/show/SK/Starter+Kit
the toucschishield work fine with preinstalled demo...
install arduino 22 and copy last touchshield firmware
in boards.txt
slide.name=TouchShield Slide
slide.upload.protocol=butterfly
slide.upload.maximum_size=258048
slide.upload.speed=57600
slide.bootloader.low_fuses=0xFF
slide.bootloader.high_fuses=0x98
slide.bootloader.extended_fuses=0xFB
slide.bootloader.path=TouchShield
slide.bootloader.file=TouchShield_boot.hex
slide.bootloader.unlock_bits=0xFF
slide.bootloader.lock_bits=0xFF
slide.build.mcu=atmega2560
slide.build.f_cpu=16000000L
slide.build.core=touchSlide
example:
COLOR red = {255,0,0};
COLOR blue = {0,0,255};
lcd_rectangle(20,20,80,80, red, blue);
set board to touchshield
then compile with no errors
so I press button s2 (i see a red led) but when i try to upload it i received this error
Connecting to programmer: .
Found programmer: Id = ""; type =
Software Version = >. Hardware Version = €.Ø
avrdude: error: buffered memory access not supported. Maybe it isn't
a butterfly/AVR109 but a AVR910 device?
There are some error in my steps?
I  also tried with other ide (antipasto, arduino 018) but the result is  same ;(
thanks
Marco
gvi70000
