Topic: [Solved] Trying to get input from pedals (Read 352 times) previous topic - next topic
Jay98
Mar 06, 2019, 08:39 pm Last Edit: Mar 07, 2019, 08:52 pm by Jay98
I have this pedals that come with a racing wheel, a PC peripheral, they connect to the wheel and the wheel to the PC via USB, I just want to take the pedals connect them to an arduino board and read their data, leaving out the wheel.
So the cable has 4 wires just like the USB standard, what I did is to apply +5V between the red and black and then connected the meter to the white and green, I was expecting to read some voltage variation as pedals are pressed but nothing happens, it's always 0.
Any idea how this is supposed to work?
lastchancename
#1
Mar 06, 2019, 08:43 pm Last Edit: Mar 06, 2019, 08:45 pm by lastchancename
Not enough info.
Do the pedals have a USB plug, or just 4 wires?
It sounds like the steering wheel has the USB interface.
You need to explore and understand what the pedals are sending.
Photo?
Brand?  Model? Datasheet?
without this info - who knows.
edited
Experienced responders have a nose for laziness, (they were beginners once)... Sure, there are trolls, chest-beaters, and pretenders - but the help you'll get here is about as good as it gets - if you try to help youself!.
Jay98
I figured it out, One of the crocodile clips I was using for the tests was faulty.  >:(
Replaced it and now it works just as expected, I get different voltages in a range of +4V / -4V according I press one pedal or the other.
[Solved]
lastchancename
