Topic: Merlin firmware serial error on upload (Read 362 times) previous topic - next topic
THE_BIG_BEAR390
i recently got a RAMPS 1.4 shield for my arduino mega
i downloaded merlin 1.1 bugfix
no change to code
i verified it works
but when i go to upload it tells me this:
Sketch uses 54526 bytes (21%) of program storage space. Maximum is 253952 bytes.
Global variables use 2513 bytes (30%) of dynamic memory, leaving 5679 bytes for local variables. Maximum is 8192 bytes.
avrdude: ser_open(): can't open device "\\.\COM3": The system cannot find the file specified.
avrdude: ser_drain(): read error: The handle is invalid.
avrdude: ser_send(): write error: sorry no info avail
avrdude: stk500_send(): failed to send command to serial port
avrdude: ser_recv(): read error: The handle is invalid.
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
the selected serial port avrdude: stk500v2_getsync(): timeout communicating with programmer
 does not exist or your board is not connected
help would be much appreciated
Thanks
pert
Make sure you have selected the port of your Arduino board from the Tools > Port menu.
Sometimes the port will be labeled with the board name in the menu. Other times it will not. If you don't know which port is your Arduino, you can find it like this:
  • Unplug your Arduino board from the computer.
  • Tools > Port
  • Note the ports, if any, listed in the menu.
  • Close the Tools menu
  • Plug your Arduino board into the computer.
  • Tools > Port - The new port listed in the menu is your Arduino board.
Does the problem still occur if you remove the RAMPS shield from your Mega?
THE_BIG_BEAR390
well i just found the problem my current title as a newbie fits because the port setting was set to serial for some reason
works now thanks
