Topic: Interface Arduino with a Car K-Line (Read 18511 times) previous topic - next topic
NewBE
Hello,
im newbie in electronics i like to connect Arduino to a K-Line PIN 7 from a OBD II car plug to communicate with ECU using arduino UART.
My knowledge are:
1) The K-Line work with > 12V
2) Arduino work with 5V
This let me think that, if i connect arduino 1 RX 2 TX pins to a K-Line i will destroy the borad without a resistor  :smiley-mr-green:
Can someone help me which has experience in electronics to create a simple circuit.
My knowledge in Electronics component are:
1) Resistors good
2) Transitor NPN PNP good
3) Capacitor good
4) Diode good
5) Opto-isolator sufficient
x) Read electronics scheme sufficient  :smiley-sweat:
In software development i have over 15y. C/C++ experience which will not compromise this project  8)
Thanks ahead for help
L0NG_J0HN
Try to look for 'opengauge' or 'OBDuino' projects on google, you will find what you need.
About the interface check out this http://ecomodder.com/forum/showthread.php/obd-mpguino-gauge-2702.html#post33255
cheers,
John
ivoryheart
Hey,
I quite new to adurino. I came to this interface, because it is used for ECU-Flash-read via AUD (AdvancedUserDiagnostic).
I allready got a code for this AUD-reading function.
For wirting the ECU a "simpe" K-line interface is used like a FTDI-chip will be.
Openecu.org recovery interface is a example for this:
http://openecu.org/downloads/shbootmode.pdf
IMO this function could be done via adurino too so I can combinate both functions or use the same interface, just flashing a other file to it ?
For wirting the ECU only 5V TTL level is used AFAIK.
Did someone try to use arduino as as a simple pasthrough interface and can provide me with code for this ?
Any hints, helps etc are wellcome
Jochen
