Topic: how to eread from a couple serial ports at once (Read 458 times) previous topic - next topic
Avram_Alter
I'm using a mega2560, and I want to take advantage of each serial port. Each one will be connected to a different RFID reader. This is the code I am working on right now:
Code: [Select]
int RFIDResetPin = 13;
pinMode(RFIDResetPin, OUTPUT);
digitalWrite(RFIDResetPin, HIGH);
Serial1.begin(9600);
char tagString[13];
int index = 0;
boolean reading = false;
while(Serial.available()){
int readByte = Serial.read(); //read next available byte
if(readByte == 2) reading = true; //begining of tag
if(readByte == 3) reading = false; //end of tag
if(reading && readByte != 2 && readByte != 10 && readByte != 13){
//store the tag
tagString[index] = readByte;
index ++;
Serial.println(tagString); //read out any unknown tag
clearTag(tagString); //Clear the char of all value
resetReader(); //eset the RFID reader
while(Serial1.available()){
int readByte = Serial1.read(); //read next available byte
//store the tag
index ++;
Serial1.println(tagString); //read out any unknown tag
void resetReader(){
//Reset the RFID reader to read again.
digitalWrite(RFIDResetPin, LOW);
delay(150);
void clearTag(char one[]){
//clear the char array by filling with null - ASCII 0
//Will think same tag has been read otherwise
for(int i = 0; i < strlen(one); i++){ one[i] = 0; } } boolean compareTag(char one[], char two[]){ /////////////////////////////////// //compare two value to see if same, //strcmp not working 100% so we do this /////////////////////////////////// if(strlen(one) == 0) return false; //empty for(int i = 0; i < 12; i++){ if(one[i] != two[i]) return false; } return true; //no mismatches }
I built it off of a single serial reader, as you can see the read functions are doubled. First one is RX0 pin, second is for RX1 pin. I'm very new to this, any help would be appreciated.
"Throw your soldiers into positions whence there is no escape, and they will prefer death to flight. If they will face death, there is nothing they may not achieve."
-Sun Tzu
Grumpy_Mike
Use Serial1 & Serial2 and Serial3, using Serial just cuts off your ability to talk through the USB port.
Avram_Alter
I attempted to do that, but I got an error that the port didnt exist. another issue is that i want to run my program on both serial1, 2, and 3, all at once
-Sun Tzu
Grumpy_Mike
Quote
Then you didn't do it right, post your code and lets see if we can spot what you did wrong.
Quote
What is stopping you? Again post your code where you try this. Basically you can't do things simultaneously only do them one after the other so quickly that it looks like it is happening at the same time.
Avram_Alter
#4
Mar 13, 2019, 05:41 pm Last Edit: Mar 13, 2019, 08:00 pm by Avram_Alter
ok here it is:
Code: [Select]
Serial2.begin(9600);
Serial3.begin(9600);
char tagString1[13];
int index = 0;
if(Serial1.available()){
int readByte1 = Serial1.read(); //read next available byte
if(readByte1 == 2) reading = true; //begining of tag
if(readByte1 == 3) reading = false; //end of tag
if(reading && readByte1 != 2 && readByte1 != 10 && readByte1 != 13){
//store the tag
tagString1[index] = readByte1;
index ++;
Serial.println(tagString1); //writes to serial monitor
clearTag(tagString1); //Clear the char of all value
resetReader(); //Reset the RFID reader
char tagString2[13];
if(Serial2.available()){
int readByte2 = Serial2.read(); //read next available byte
if(readByte2 == 2) reading = true; //begining of tag
if(readByte2 == 3) reading = false; //end of tag
if(reading && readByte2 != 2 && readByte2 != 10 && readByte2 != 13){
//store the tag
tagString2[index] = readByte2;
index ++;
Serial.println(tagString2); //read out any unknown tag
clearTag(tagString2); //Clear the char of all value
char tagString3[13];
if(Serial3.available()){
int readByte3 = Serial3.read(); //read next available byte
if(readByte3 == 3) reading = false; //end of tag
if(reading && readByte3 != 2 && readByte3 != 10 && readByte3 != 13)  //store the tag
tagString3[index] = readByte3;
index ++;
Serial.println(tagString3); //read out any unknown tag
clearTag(tagString3); //Clear the char of all value
void resetReader() //Reset the RFID reader to read again.
  return false;
I really am new at this, I was basically thrown headlong into a project. In essence, I want an RFID reader to scan a tag, and then send the number of the scanned tag to the serial monitor. It also makes the mega continuously write to the serial monitor with null when there is no tag detected. This code compiles and uploads really nicely, but then does nothing. the rx light on the chip doesn't go on, and nothing appears in the serial monitor.
-Sun Tzu
PaulRB
Your code is almost impossible to read. Well done for posting it in code tags, but please post it again, after you have performed an auto-format (tools menu).
I do not see Serial.begin() in setup().
Grumpy_Mike
Code: [Select]
//store the tag
index ++;
That code can only read one byte and then the code that follows it writes one byte to the serial monitor and then wipes the value you have got.
Thing is you are trying to do too much all at once. Start of with just reading one serial port and put it in a function. When that is working you can extend this to use the other two readers.
