Topic: Relay pro tips - Commutating diode (Read 478 times) previous topic - next topic
Geek Emeritus
one of those things that is obvious when it's explained, but not before:
  • if you run a current through a wire, you generate a magnetic field
  • if you pass a magnetic field across a wire, you generate a current
  • if you pass a current through a coil of wire you get a larger magnetic field, because more wire
  • if you cut off that current, the larger magnetic field collapses
  • back into the coil
  • generating a reverse polarity voltage spike back into the current source
  • which explains the vast blue spark when you unplug a coil
and your Arduino eats that reverse spike. On an old Triumph motorcycle, 6 volt coils, I measured 321 V spikes when the points opened.
which is why NASA was insistent that the products they bought have a relay across the diode, with a high enough PIV Peak Inverse Voltage rating to shunt the voltage spike to ground or the regulated power supply:
you have the same situation on the load side. in the drawing above, if COM is a power source, and NO & NC both go to inductive loads, both NO & NC need a diode that is reverse biased to the load voltage, shunting the reverse spike from the load to ground. A diode on COM can't work, because it will be disconnected at the precise time i8t is needed.
it is called a commutating diode. this is not a particular kind of diode, like a zener or Schottky diode. It's a generic diode that is used to mitigate the effect of polarity reversal.
https://www.allaboutcircuits.com/textbook/semiconductors/chpt-3/inductor-commutating-circuits/
SSRs do not need commutating diodes on the  5 volt logic side, but use them on the load side.
All PMs will be deleted unopened due to arrogant argumentative pot stirring Malfoys.
 If you have not read "How to use this forum - please read", in particular: "7. If you are posting code or error messages, use "code" tags":  expect rude responses
lastchancename
A decent post, but the title is trying to make it sound important.
Adding a relay isn't a *pro* tip - it's fundamental.
Perhaps thread should be renamed -
WHY DO I NEED A DIODE ACROSS MY RELAY.
Experienced responders have a nose for laziness, (they were beginners once)... Sure, there are trolls, chest-beaters, and pretenders - but the help you'll get here is about as good as it gets - if you try to help youself!.
