Topic: Help with a full code Any Generous programmer? (Read 364 times) previous topic - next topic
DRAMMACHINE
help help help  i need to modify this code for to motors ! can somebody help me !it is work  for me but only for one side of the tank !!! i want use 2 joystick. is it  possible >?
   Example code to control a DC motor forward and reverse with variable speed
   using a L298N driver board, an Arduino, and a typical RC Controller
   driver board: $7
       https://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=L298N
   flysky rc controller transmitter and receiver: $50
       https://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias%3Daps&field-keywords=fs-t6&rh=i%3Aaps%2Ck%3Afs-t6
   video overview:
       https://www.youtube.com/watch?v=v_N5HmXmDyk&feature=youtu.be
int in1 = 12;
int in2 = 13;
//the following are all ~PWM capable ports
int enable1 = 11;
int rc_channel4 = 3;
int switchD = 5;
  pinMode(rc_channel4, INPUT);
  pinMode(switchD, INPUT);
  pinMode(in1, OUTPUT);
  pinMode(in2, OUTPUT);
  pinMode(enable1, OUTPUT);
  int pwm = 0;
  int swd = pulseIn(switchD, HIGH, 25000);
  int rc4 = pulseIn(rc_channel4, HIGH, 25000);
  Serial.print("switch: ");
  Serial.print(swd);
  Serial.print(" raw channel4: ");
  Serial.print(rc4);
  if(rc4==0){
      Serial.println(" no signal");
      digitalWrite(in1, LOW);
      digitalWrite(in2, LOW);
      analogWrite(enable1, 0);
  else if(rc4 > 1530){ //right stick
      pwm = map(rc4, 1530, 2000, 0, 255); //map our speed to 0-255 range
      digitalWrite(in2, HIGH);
      analogWrite(enable1, pwm);
      Serial.print(" right stick speed: ");
      Serial.println(pwm);
  else if(rc4 < 1460){
      pwm = map(rc4, 1460, 1000, 0, 255); //map our speed to 0-255 range
      digitalWrite(in1, HIGH);
      Serial.print(" left stick speed: ");
  }else{
      Serial.println(" stick centered");
  delay(10);
wvmarle
#1
Mar 15, 2019, 09:24 am Last Edit: Mar 15, 2019, 09:24 am by wvmarle
Motors?
Tank? What's stored in it? Why does a tank have motors? Or different kind of tank than I'm thinking of maybe.
One side - what other side?
Joysticks?
Too many unknowns to even start looking at the code.
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
cedarlakeinstruments
Guess you're not generous enough ;-)
Electronics and firmware/software design and assistance. No project too small
