Topic: 8x5 RGB LED matrix help! (Read 1 time) previous topic - next topic
cl10Greg
Hello all,
I am trying to make a 8x5 LED matrix.  The concept has a module that has an IR sensor and 4 RGB leds per module.  There are 10 modules.  If IR is detected, turn on the 4 RGB leds.  The leds can be changed in color individually so that is whay I am making a matrix.  I plan on using a 8 bit shift register for the rows and a TLC5940 for the 5 (which is actually 15 since they are RGB LEDS) columns.  I have captured the picture of this concept and attached it.
My questions are...
I was using a shiftout code to count from 0 to 10 and was monitoring the Qa pin.  I was seeing the following results in the window: 0,-1,-1,0,-1,0,-1,0,-1,0,-1.  This confused me (probably because I haven't used shift registers once).  I was doing MSBFirst.  I was thinking maybe this was sending the bits as binary and that does not correspond with what I see.  Any help on this?
Do I need to use the transistor array since I am doing multiplexing?  I figured I would because of the current to light up the columns.
How would the code go to run this?  I was thinking maybe to read the sensors, send the shift register command, then to jump to the TLC serial.  Do you see a problem with this?  Is the arduino fast enough for this to make a good lighting effect?
I think as far as I/O goes I should be good.  There are 3 lines for the shift register, 4 for the TLC5940, and 5 for the mux.  Making 12 I/O which the Dumenilove has.
I guess I am just probing to see what is fesible or if I am doing this the hard way.  Any suggestions would be appreciated.
Thanks!
Grumpy_Mike
