Topic: Constant low speed (Read 447 times) previous topic - next topic
sinan
Hello, I am Turkish. I'm sorry for English. I need to rotate the Nema 17 engine at a constant speed. The speed should be clocked. For example, 5 rpm. Is there any code that can help?
mugambi
Sample code from the stepper library will help you. If you need further help let me know. I will charge though.
sinan
Hello. What is the name of the sample code?
Thanks.
mugambi
Arduino ide-examples .. Stepper..
sinan
I tried all the samples in this library. I don't have a tool to measure rpm. Can I make the speed both low and constant with the NE555?
cedarlakeinstruments
If you can't measure RPM, how were you planning on verifying that it works in the first place?
Electronics and firmware/software design and assistance. No project too small
sinan
That's why I need a code that gives me the rpm that I'm sure is correct.
cloxart
You can easily use the arduino itself to measure the time of rotation
Based on the responses, clearly nothing will be easy for him.
cloxart
Then he should be ready to pay someone lol
sinan
#10
Mar 18, 2019, 07:55 pm Last Edit: Mar 18, 2019, 07:57 pm by sinan
I'm ready to pay.I'll use this code for ball clock.I'll make a clock like the following link.
https://www.youtube.com/watch?v=jkgpthZlBmY&t=0s&list=LL1EKuoRBFkTp3Cgcw97tZ6g&index=57
patduino
Do you have the motor and driver yet?  See my PM for options if you're still looking.
There are 10 types of people in the world, those who understand binary, and those that don't.
sinan:
If you're building a clock, the standard method is to use a synchronous motor like this one. Give it a 12VAC signal (from a transformer) and it will rotate all day at a very accurate 5RPM. No arduino needed.
cloxart
As my nickname and picture here shows, building wooden clocks is one of my hobbies... In this case I strongly agree with cedarlakeinstruments, a synchronous motor is the best and simplest solution. A stepper motor will be noisy and at each single step will tend to "shake" the gears. Only thing, you should not use a "CW/CCW" motor. "CW/CCW" means that when you power it up it can start rotating in any direction at random. Look for one that has only CW or CCW in the specs, depending on the direction you want it to rotate.
