All,
I am only prototyping at the moment and have no intention of keeping anything running unless it is for testing.
PerryBebbington, I have a triac switch that I control for dimming. It has a bridge rectifier on it so would that also mean it doesn't have a 0V or ground connection?
This is what I'm thinking for the setup:
https://cdn.instructables.com/FMT/P75C/I24LZHBT/FMTP75CI24LZHBT.LARGE.jpgPerry, if I make a bridge rectifier as shown in the link above how does the DC side not have a ground connection? What specifically is +ve and -ve, the alternating current part? From my limited understanding wouldn't the DC part of the circuit always have a lower potential path to either the hot and neutral side of the socket? I can see how it wouldn't have a ground path as it passes electricity down the hot wire.
I understand that there are dangers with using 120V AC and I have no intention of doing anything dangerous. However, I do try my best to understand exactly what is happening with the things I build, 99% of the time in concept and thought experiment before even daring to attempt a test.
Guys please tell me:
1. How can I set up a full bridge rectifier (with or without a breadboard) to make DC-like current that I can step down as needed for other components and exercise appropriate control? (PWM or any other means)
2. How can I always ensure all parts of the circuit have a safe path to ground?
Tom, I only want to harness 120V but yes I suppose I can get up to 170V with a larger capacitor correct?
The reason I ask all this is because as an engineer (I'm a process engineer), I am not content with just using components others have already built, because my aim is to truly understand the internals of the circuit. I place more value in the process of building, designing, troubleshooting, and debugging; I place little value on the end product because I try to be a continuous learner.
Thanks everybody
