Topic: Parallel in serial out access in bit wise (Read 78 times) previous topic - next topic
AJITnayak
Dear all.
I have sample code below.FAULT_PISO is variable which hold value of serial out. I could able to get Serial output from device .
I wanted to use the bit value of variable how can i do in it.
for example FAULT_PISO=0X10
then i wanted to read 8 bit of FAULT_PISO value.  1000 0000  in this i wanna access 8 bit value  which i wanted to use for comparing with enum value.
if enum value is == FAULT_PISO_8bit
led =on
led =off
Code: [Select]
int PISO_CLK = 3 ; // Output its clock input for 74hc765 connected to PIN2
int PISO_FAULT = 4; // Serial I/p (Q7) Connected to PIN 9 of 74HC765
int PISO_PL_EN = 5; // Load input for Connected to PIN 1 of 74HC765
unsigned char PISO_CLK_EN = 0;
unsigned char byteValue = 0;
unsigned char bitValue;
volatile unsigned char FAULT_PISO;
void CHK_FAULT_INPUT(void) {
  unsigned char i;
  byteValue = 0; // accumulates image of 8 switches
  bitValue = 0;
  PISO_PL_EN = 0; // latch data
  delayMicroseconds(200);
  PISO_PL_EN = 1; //ADD
  for (i = 0; i < 8; i++) {
    bitValue = PISO_FAULT;
    byteValue |= (bitValue << ((8 - 1) - i));
    PISO_CLK = 1;
    PISO_CLK = 0;
  FAULT_PISO = byteValue;
  Serial.print("FAULT_PISO:");
  Serial.println(FAULT_PISO);
  pinMode(3, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(4, INPUT);
  CHK_FAULT_INPUT();
AMPS
PaulS
