I am attempting to use a Catalex MicroSD Card Adapter (V1.0 09/02/20133), and am having issues with SD card initialization. I have tried different microSD cards, reformatted, and different Catalex adapters (same version).
I have also tried the solutions found in this thread, including jumping the appropriate wire.
Any ideas on what is wrong/how I can resolve the issue? Pin layout is correct.
The MISO pin (7) of card need a pul-up resistor (10k~100k) when there is no pull-up in the microcontroller.
However, in this case, the Catalex has a buffer between microSd Card socket and the microcontroller pin.
The solution is put the pull-up close to the socket.
lepoloni could you please attach the picture/photo for catalex mod that you have inserted (image is not clear)...
I hope this will help in my SPI multiple connections.....!!
beetlenut:
