Topic: using pullstime  (Read 2664 times) previous topic - next topic
UKHeliBob
Code: [Select]
  if (buttonPushCounter % 1 == 0 {
No closing bracket on the if
In any case, the remainder when dividing an integer by 1 will always be zero
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
Matyk
#16
Mar 22, 2019, 11:34 am Last Edit: Mar 22, 2019, 11:35 am by Matyk
If I don't say that the int long unsigned gives me this: too many arguments to function 'long unsigned int millis()'
UKHeliBob
Stop thrashing about and think logically.
For instance
Code: [Select]
const int myPulseTime = millis(1500);
millis() returns a value.  What is the 1500 about ?
Matyk
it is 15 milliseconds, if the ESC gets 1500 it does not output any speed, 1500- 2000 is the actual speed
Matyk
and do you know how I could solve the: two or more data types in declaration of 'buttonPin'
Matyk
// Should it be like this
Code: [Select]
#include <Servo.h>
Servo m1;
int unsigned long
const int buttonPin = A2;
const int ledPin = 9;
const int myPulseTime = writeMicroseconds(1500);
const int pulseIncrement = writeMicroseconds(250);
const int myPulseTime = (myPulseTime + pulseIncrement);
int buttonPushCounter = 0;   // counter for the number of button presses
int buttonState = 0;         // current state of the button
int lastButtonState = 0;
/ initialize the button pin as a input:
  pinMode(buttonPin, INPUT);
  // initialize the LED as an output:
  pinMode(ledPin, OUTPUT);
  // initialize serial communication:
  buttonState = digitalRead(ButtonPin);
  if (buttonPushCounter % 1 == 0) {
  m1.attach(9);
    m1.write myPulseTime = (myPulseTime + pulseIncrement);
    delay(1);
    m1.writeMicroseconds(1000);
    delay(1);
    if (buttonPushCounter % 2 == 0) {
      m1.attach(9);
      delay(1);
      delay(1);
      if (buttonPushCounter % 3 == 0) {
        m1.attach(9);
        delay(1);
        delay(1);
UKHeliBob
Quote
No
buttonPin is presumably the number of a pin.  It will not change in the program and it will not have a value of greater than 255 so a byte will be large enough to hold the value
So it should be
Code: [Select]
const byte buttonPin = A2;
and delete the previous line
Matyk
did that thanks man, but I still get the "too many arguments to function 'long unsigned int millis()'" if i delete the thing.
johnwasser
Code: [Select]
You are trying to declare "myPulseTime" as two different constants.  One of those will have to change names.
writeMicroseconds(1500) is not a constant.  Use 1500 instead.
writeMicroseconds(250) is not a constant.  Use 250 instead.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
Matyk
Thanks so much, everything is working, but the damn thing is now saying: expected ';' before 'myPulsetime'
at the last segment ( the part before the special symbols).
Matyk
Code: [Select]
#include <Servo.h>
Servo m1;
const int mypulseTime =  (1500);
const int pulseIncrement = (250);
const int myPulsetime = (mypulseTime + pulseIncrement);
  // initialize the button pin as a input:
  buttonState = digitalRead(buttonPin);
    m1.attach(9);
    m1.write myPulsetime = (myPulseTime + pulseIncrement);
    delay(1);
    delay(1);
      m1.attach(9);
      m1.write myPulsetime = (mypulseTime + pulseIncrement);
      delay(1);
      delay(1);
        m1.attach(9);
        delay(1);
        delay(1);
UKHeliBob
It can't be working if you are still getting errors while compiling
Post the code as it is now and the full error message
Matyk
#27
Mar 22, 2019, 08:58 pm Last Edit: Mar 22, 2019, 09:48 pm by Matyk
#include <Servo.h>
Servo m1;
const int mypulseTime =  (1250);
    m1.attach(9);
    delay(1);
    delay(1);
      m1.attach(9);
      delay(1);
      delay(1);
        m1.attach(9);
        delay(1);
        delay(1);
Arduino: 1.8.7 (Mac OS X), Board: "Arduino/Genuino Uno"
/Users/matyaskloc/Desktop/ESC-ARDUINO-CONTROL/ANother_one/ANother_one.ino: In function 'void loop()':
ANother_one:29:14: error: expected ';' before 'myPulsetime'
ANother_one:29:58: error: invalid use of non-static member function
ANother_one:39:16: error: expected ';' before 'myPulsetime'
ANother_one:39:60: error: invalid use of non-static member function
ANother_one:49:18: error: expected ';' before 'myPulsetime'
ANother_one:50:17: error: invalid use of non-static member function
         delay(1);
exit status 1
UKHeliBob
Code: [Select]
What are you trying to write to the servo ?
Matyk
Servos and ESCs get the same kind of signal, 50Hz signal. The pulse signal varies from 1ms to 2ms, with 1ms represents the motor off completely and 2ms is the maximum speed and anything between is also varying speed.
so technically what I am trying to do is, for the first press of the button the signal would be 1500 (1250+250) so middle speed, second press it would be 1750 (1500+250) 3/4 of the max speed and for the third click, it would be 2000 (1750+250).
