Topic: DIY ultrasonic sensor (Read 1 time) previous topic - next topic
fuh
Any if you guys has built an ultrasonic sensor ?
I've just replied to a related topic and started wondering that this should be a good week-end project.
Searching here at the forum got this.
It says that the shortest measurable distance is ~30cm (1 foot), I would like to measure stuff up to 5cm (~2 inches) or even lower.. what modifies the "short-range" of such sensor ?
http://creativecommons.org/licenses/by-nc-sa/3.0/
AWOL
It's a while since I did one from scratch, but here are some of the pitfalls:
1) Cheap transducers tend to ring after you drive them, so you give them, say 10 cycles of 40kHz, but they actually transmit more like 15 or 20 because of ringing. This may limit your measurement rate. I have never seen a smiple way to damp them.
2) wavelength of 40kHz in air is about 8mm. Without phase detection, it is tricky to get better resolution than this.
fuh
I was thinking about water level measurement suing a chep DIY sensor, the rate it's not that important.. but the "short" range is.
As I'm not a native speaker I assume resolution is not the same as range, so what the meaning of resolution onto this context ?
I'm afraid, Dave; My mind is going; I can feel it..
It just happen to love 2001. :-)
AWOL
Quote
Resolution is the fineness of measurement.
If your timer can measure down to, say, 4 microseconds (in air) that means (in theory) that you can resolve just over 1mm in range. (Wavelength about 8mm at 40kHz, or 25 usec).
That's the theory, but how rapidly the receiver responds to the incoming pulse is a different matter.
You may find that you don't get significant signal until after ther first four or five received cycles.
Water is tricky, and I confess I haven't done any ultrasound in water.
However, the speed of sound in water is about 4.5 times that in air - nearly 1500m/s, so timing is even more critical.
Quote
Probably the first and last time I cried at the movies.
Congratulations! You're probably the first person to get the joke, and a non-English speaker at that!
I'm hugely impressed.
Some people even think my name is Dave.
As if!
fuh
-offtopic-
I love Kubrick films, one may not say to like movies if haven't seen a Kubrick's film.
HAL was one of my favorite characters, how can someone do not know it and the "Dave" speech ?
Did you know that HAL was rated 13th on the greatest villains ?
-offtopic-
Actually what was confusing me was I asking about range and you spoken about resolution.
So can I say that the short range depends on the speed of the chip (328p for instance) to process the signals and the actual physical limit of a 40kHz wave ?
If in 25usec I can measure 8mm, to measure 50mm I would need ~157usec; on that period 6.28 40kHz waves have left the tx sensor; am I getting this ?
I believe it is tricky in other sense; the objective is to measure the top of the water column and for that the waves should reflect without going into the bottom of the tank; the problem may be the weakness of the signal being reflected by the top of the water column.
I've search the internet and found some schematics that use inductors, that should be increase the high range of the sensor ?
