Topic: MIDI output/power issue (Read 608 times) previous topic - next topic
RDF_MIDI
Mar 22, 2019, 03:40 pm Last Edit: Mar 22, 2019, 04:01 pm by RDF_MIDI
I recently built a MIDI controller, which is sorta like a keyboard played with your feet, using an Arduino Uno.
When I power the Uno through USB (like when I'm sending the sketch to it) from my computer, everything works exactly as it should. All of the note and function keys put out the correct values to the MIDI jack when read in MIDI-OX.
When I try to power it *ANY* other way, all I get is a constant stream of random data at the MIDI jack.
I've tried everything from 5V to 12V switching power supplies going into the Uno's power connector. I've even tried a MB102 breadboard power supply going into the USB connector on the Uno. Always the same result - a constant stream of gibberish.
Any recommendations?
Grumpy_Mike
Quote
This means either your power supply is wrong or you are not wiring it correctly. But as you have not supplied any detail of what you have done it is hard to say what you have done wrong.
RDF_MIDI
I'm at work right now, but I can post schematics later today.
Grumpy_Mike
RDF_MIDI
Here are the schematics. Do you need the sketch as well?
MarkT
Ironically the only part of the circuit not in the schematic is the midi output jack, just some
written descriptions - although it sounds plausible, only pins 5 and 4 are mentioned, 2 (GND)
is not mentioned.
Best to draw the midi output circuit to be absolutely certain.
It strikes me you don't have an isolated MIDI input circuit on the machine running MIDI-OX?
If that's so and there is no ground connection, that would explain it.
MIDI requires an opto-isolated input circuit to be reliable as designed, using a com port and some windows
utility is not proper MIDI.
Grumpy_Mike
#6
Mar 23, 2019, 08:08 am Last Edit: Mar 23, 2019, 08:09 am by Grumpy_Mike
Quote
Yes I quite agree with that conclusion.
By using the computer's power through the USB port you automatically get a ground connection.
RDF_MIDI
Yes, the MIDI is shown as grounded. On the power pins for the Uno, the one labeled as pin 7.
But here it is drawn out.
Yes, I'm using an isolated MIDI adapter going to my computer's USB port.
Grumpy_Mike
#8
Mar 23, 2019, 06:12 pm Last Edit: Mar 23, 2019, 06:15 pm by Grumpy_Mike
Can you please read reply #1 again.
You are not showing us what you have done to power the system when it goes wrong. Schematic and photograph of an unsuccessful attempt at powering would help.
There is no need to connect ground to your MIDI connector.
Is it correct you connect pin 2 to the MIDI output?
RDF_MIDI
#9
Mar 23, 2019, 07:44 pm Last Edit: Mar 23, 2019, 07:50 pm by RDF_MIDI
In this image, power comes from my computer via USB to the onboard USB port on the Uno.
MIDI data goes out pin 2, through a 220 ohm resistor, to pin 5 of the MIDI jack, through a USB/MIDI adapter, and into my computer, which is running MIDI-OX.
In this configuration, all MIDI data is read correctly.
RDF_MIDI
#10
Mar 23, 2019, 07:56 pm Last Edit: Mar 23, 2019, 08:07 pm by RDF_MIDI
In this image, power comes from a 9VDC switching power supply to the power jack on the Uno. There is nothing plugged into the USB port on the Uno.
MIDI data follows the same path. It goes out pin 2, through a 220 ohm resistor, to pin 5 of the MIDI jack, through a USB/MIDI adapter, and into my computer, which is running MIDI-OX.
In this configuration, there is a steady stream of random MIDI data going out of the MIDI jack.
I've tried using a 5VDC and a 12VDC adapter with the same result.
RDF_MIDI
#11
Mar 23, 2019, 08:04 pm Last Edit: Mar 23, 2019, 08:07 pm by RDF_MIDI
In this image, power comes from a 9VDC switching power supply, to a breadboard power supply with a built-in 5V regulator, through a USB cable to the USB connector on the Uno.
RDF_MIDI
Suggestions? Recommendations? Ideas?
