In this image, power comes from a 9VDC switching power supply, to a breadboard power supply with a built-in 5V regulator, through a USB cable to the USB connector on the Uno.
MIDI data follows the same path. It goes out pin 2, through a 220 ohm resistor, to pin 5 of the MIDI jack, through a USB/MIDI adapter, and into my computer, which is running MIDI-OX.
In this configuration, there is a steady stream of random MIDI data going out of the MIDI jack.
