Topic: Designed a own PCB and a button doesn't work (Read 282 times) previous topic - next topic
timtailors
Mar 22, 2019, 05:22 pm Last Edit: Mar 22, 2019, 05:23 pm by timtailors
I wired a button in pull-down mode at PA13 of a SAMD21 chip.
I can read the status of the pin which works. When pushing the button Serial.print returns "1" and when not "0".
So the wiring and pin mapping seems correct.
However since weeks I couldn't figure out a strange behaviour with one library:
https://github.com/arduino-libraries/ArduinoLowPower
I need to put it to sleep and wake it on Porta 13.
I would be very grateful if anyone know a solution to this
That's my test code which doesnt wake up
Code: [Select]
#include "Arduino.h"
#include "ArduinoLowPower.h"
#define ENCODER_BUTTON 43    // PA13, physical IC PIN 22
volatile int i = 0;
  pinMode(ENCODER_BUTTON, INPUT);
  Serial.println("Start");
  LowPower.attachInterruptWakeup(ENCODER_BUTTON, encoder_int_func, RISING);
  LowPower.sleep();
  Serial.print(i); Serial.println(digitalRead(ENCODER_BUTTON));
void encoder_int_func() {
  i = 1;
  Serial.println("encoder_int_func");
That's my variant.cpp
Code: [Select]
// 43 .. 46 - EDBG/Digital
  { PORTA, 13, PIO_PWM, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), No_ADC_Channel, PWM0_CH5, NOT_ON_TIMER, EXTERNAL_INT_13 }, // EIC/EXTINT[13] *TCC2/WO[1] TCC0/WO[7]
  { PORTA, 21, PIO_PWM_ALT, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), No_ADC_Channel, PWM0_CH7, NOT_ON_TIMER, EXTERNAL_INT_NONE }, // Pin 7
  { PORTA,  6, PIO_PWM, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), No_ADC_Channel, PWM1_CH0, NOT_ON_TIMER, EXTERNAL_INT_NONE }, // Pin 8
  { PORTA,  7, PIO_PWM, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), No_ADC_Channel, PWM1_CH1, NOT_ON_TIMER, EXTERNAL_INT_NONE }, // Pin 9
krlnokrl
I think your code is a bit mixed up.
You want the LowPower.sleep(); to be at the end of your loop, after the Serial.print
Also The official code says:  // Remember to avoid calling delay() and long running functions since this functions executes in interrupt context
So i don't feel like the encoder_int_func() should have the call to the Serial.print Although that shouldn't cause these problems.
What output do you get after switching the things around like that?
