Topic: Undefined reference to for a class (Read 369 times) previous topic - next topic
Bugflip
When  I compile my main code, it gives me an error and I read up about it but couldn't find anything.
Code: [Select]
 * The Effect abstract class for the GauntletII project.
#ifndef Effect_h
#define Effect_h
#import <FastLED.h>
class Effect {
    protected:
        CRGB *leds;
        int width, height;
        struct CRGB& pixel(int x, int y);
        bool inXRange(int x);
        bool inYRange(int y);
        void clearLeds();
    public:
        Effect(CRGB *leds, int width, int height);
        virtual void start() {};
#endif
Code: [Select]
Arduino: 1.8.8 (Mac OS X), Board: "Arduino/Genuino Uno"
In file included from sketch/Effect.h:8:0,
                 from sketch/twinkle.cpp:5:
/Users/jonathanfelix/Documents/Arduino/libraries/FastLED/FastLED.h:17:21: note: #pragma message: FastLED version 3.002.000
 #    pragma message "FastLED version 3.002.000"
                 from sketch/twinkle.cpp:5,
                 from /Users/jonathanfelix/Documents/Arduino/sd_card_lights/sd_card_lights.ino:4:
/var/folders/sn/s5gtxzh907q8mmf73yr8fjs40000gn/T//ccEmA6Db.ltrans1.ltrans.o: In function `Twinkle::Twinkle(CRGB*, int, int, bool, bool)':
sketch/twinkle.cpp:27: undefined reference to `Effect::Effect(CRGB*, int, int)'
collect2: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
gfvalvo
You posted incomplete code. Please supply enough so that we can reproduce the same compiler error.
No technical questions via PM. They will be ignored. Post your questions in the forum so that all may learn.
Bugflip
the rest is really messy I need to organize it and get rid of some variables I'm not using.
Code: [Select]
#include "twinkle.cpp"
int crn = 1;
#define HEIGHT 14
#define WIDTH 14
#include <FastLED.h>
#define NUM_LEDS WIDTH * HEIGHT
#include <SPI.h>
#include <SD.h>
#define DATA_PIN 3    // your data arduino pin
#define CHIPSET WS2812B  // your LED chip type
#define CMD_NEW_DATA 1
//#define BAUD_RATE 500000  //if using Glediator via serial
const byte interruptPin = 2;
unsigned char x = 14; // matrix x size
unsigned char y = 14; // matrix y size
volatile int buttoncount = 0;
static unsigned long last_interrupt_time = 0;
#define MAX_TWINKS 25
#define OFFSET 0xB000
File fxdata;
CRGB leds[NUM_LEDS];
void irpt(){
  unsigned long interrupt_time = millis();
  // debounce
  if ((interrupt_time - last_interrupt_time) > 100)
  if(buttoncount==8){
    buttoncount=0;
  buttoncount++;}
  Serial.println(buttoncount);
  last_interrupt_time = interrupt_time;
  pinMode(interruptPin, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(interruptPin), irpt, LOW);
  FastLED.addLeds<CHIPSET, DATA_PIN, GRB>(leds, NUM_LEDS); //see doc for different LED strips
//  Serial.begin(BAUD_RATE); // when using Glediator via usb
  for(int y = 0 ; y < NUM_LEDS ; y++)
    leds[y] = CRGB::Black; // set all leds to black during setup
  FastLED.show();
  pinMode(10, OUTPUT); // CS/SS pin as output for SD library to work.
  if (!SD.begin(4))
    Serial.println("sdcard initialization failed!");
    return;
  Serial.println("sdcard initialization done.");
int serialGlediator ()
{while (!Serial.available()) {}
 return Serial.read(); }
void loop(){
//first
  while(buttoncount==0){
  if (buttoncount!=0){fxdata.close(); break;}
  fxdata = SD.open("pl.dat");
  Serial.println("Good");
    fxdata.close();
  if (fxdata){
      fxdata.close();
  while (fxdata.available()){
      fxdata.close();
    fxdata.readBytes((char*)leds, NUM_LEDS*3);
      fxdata.close();
    ledSort(crn);
      fxdata.close();
        }//1-4 possible, set your first LED's position. Change the number: 1=TL(top left),2=TR(top right),3=BL(bottom left),4=BR(bottom right)
     FastLED.show();
      fxdata.close();
    delay(10);
      fxdata.close();
        }// set the speed of the animation. 20 is appx ~ 500k bauds
            fxdata.close();
  fxdata.close();
//second
while(buttoncount==1){
  if (buttoncount!=1){
    fxdata.close();
            break;}
  fxdata = SD.open("slow.dat");
    fxdata.close();
  if (fxdata){
      fxdata.close();
      fxdata.close();
      fxdata.close();
    ledSort(crn);
      fxdata.close();
     FastLED.show();
      fxdata.close();
    delay(10);
      fxdata.close();
            fxdata.close();
  fxdata.close();
//third
while(buttoncount==2){
  if (buttoncount!=2){
    fxdata.close();
            break;}
  fxdata = SD.open("cplasma.dat");
    fxdata.close();
  if (fxdata){
      fxdata.close();
      fxdata.close();
      fxdata.close();
    ledSort(crn);
      fxdata.close();
     FastLED.show();
      fxdata.close();
    delay(10);
      fxdata.close();
            fxdata.close();
  fxdata.close();
//fourth
while(buttoncount==3){
  if (buttoncount!=3){
    fxdata.close();
            break;}
  fxdata = SD.open("fire.dat");
    fxdata.close();
  if (fxdata){
      fxdata.close();
      fxdata.close();
      fxdata.close();
    ledSort(crn);
      fxdata.close();
     FastLED.show();
      fxdata.close();
    delay(20);
      fxdata.close();
            fxdata.close();
  fxdata.close();
Heres the first part its too big to post at one time
johnwasser
The Effect.cpp file is not being included in your build (or it doesn't define the object constructor).
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
See who has no social life: https://forum.arduino.cc/index.php?action=stats :)
gfvalvo
#4
Mar 22, 2019, 08:47 pm Last Edit: Mar 22, 2019, 08:48 pm by gfvalvo
Code: [Select]
That, in itself is an unusual thing to do.
Agreed. Better to post an MCVE
Bugflip
and heres the second part
Code: [Select]
//fifth
while(buttoncount==4){
  if (buttoncount!=4){
    fxdata.close();
            break;}
  fxdata = SD.open("frac.dat");
    fxdata.close();
  if (fxdata){
      fxdata.close();
      fxdata.close();
      fxdata.close();
    ledSort(crn);
      fxdata.close();
     FastLED.show();
      fxdata.close();
    delay(20);
      fxdata.close();
            fxdata.close();
  fxdata.close();
//sixth
while(buttoncount==5){
  if (buttoncount!=5){fxdata.close();break;}
  if (buttoncount!=5){fxdata.close();break;}if (fxdata){
  if (buttoncount!=5){fxdata.close();break;}}
      fxdata.close();
      fxdata.close();
    ledSort(4);
      fxdata.close();
     FastLED.show();
      fxdata.close();
    delay(10);
      fxdata.close();
            fxdata.close();
  fxdata.close();
//seventh
while(buttoncount==6){
  if (buttoncount!=6){fxdata.close();break;}
  fxdata = SD.open("sd.dat");
  if (buttoncount!=6){fxdata.close();break;}if (fxdata){
  if (buttoncount!=6){fxdata.close();break;}}
      fxdata.close();
      fxdata.close();
    ledSort(4);
      fxdata.close();
     FastLED.show();
      fxdata.close();
    delay(10);
      fxdata.close();
            fxdata.close();
  fxdata.close();
//eight
while(buttoncount==7){
  if (buttoncount!=7){fxdata.close();break;}
  fxdata = SD.open("lines.dat");
  if (buttoncount!=7){fxdata.close();break;}if (fxdata){
  if (buttoncount!=7){fxdata.close();break;}}
      fxdata.close();
      fxdata.close();
    ledSort(4);
      fxdata.close();
     FastLED.show();
      fxdata.close();
    delay(10);
      fxdata.close();
            fxdata.close();
  fxdata.close();
while(buttoncount==8){
  doTwinkle();
void doTwinkle() {
    Twinkle twinkle(leds, WIDTH, HEIGHT, true, true);
    twinkle.start();
int ledSort (int modus) { //1=TL,2=TR,3=BL,4=BR, this function will rearrange the led array ;-)
 CRGB tmp[x];
    if(modus == 3 || modus == 4) {
  for(int i = 0; i < (y / 2);i++) {
      for(int j = 0; j < x;j++) {
    tmp[j] = leds[i * x + j];
    leds[i * x] = leds[(y - i - 1) * x];
    leds[(y - i - 1) * x] = tmp[j];
     if(modus == 1 || modus == 3) {
       for(int i = 1; i < y; i = i + 2) {
       for(int j = x; j > 0;j--) {
        tmp[(x - j)] = leds[i * x + j - 1];
      leds[i * x + j] = tmp[j];
     if(modus == 2 | modus == 4) {
      for(int i = 0; i < y; i = i + 2) {
      return 1;
gfvalvo
Code: [Select]
#import <FastLED.h>
We don't '#import' in C++.
Bugflip
Code: [Select]
what should I do then?
gfvalvo
