Topic: mm to cm or inches (Read 420 times) previous topic - next topic
sdzafar
This IS code (credit https://youtu.be/d7VzVV2itAo  and  https://youtu.be/Zejn2yLxjUs).
Please anybody can explain to me how to change wire length mm to cm or inches.
(already try to replace "mm" to "cm" but not working, stepper motor take steps in mm)
//------------------------------- librarys ----------------------------------
#include <LiquidCrystal.h>
#include <Servo.h>
//------------------------------- lcd ----------------------------------
LiquidCrystal lcd(12, 11, 2, 3, 4, 5);
//------------------------------- stepper ----------------------------------
#define stepPin 7
#define dirPin 8
//------------------------------- servo ----------------------------------
Servo snippers;
#define servo 10
#define openAngle 180
#define closedAngle 0
//------------------------------- input ----------------------------------
#define leftButton 14
#define rightButton 9
#define upButton 15
#define downButton 6
//------------------------------- user settings ----------------------------------
unsigned int wireLength = 0;
unsigned int wireQuantity = 0;
//------------------------------- system settings ----------------------------------
int state = 0;
int incrementSpeed = 1;
int previousWireLength = 0;
int previousWireQuantity = 0;
float mmPerStep = 0.18096;
  lcd.begin(16, 2); //LCD columns and rows
  pinMode(upButton, INPUT_PULLUP);
  pinMode(downButton, INPUT_PULLUP);
  pinMode(leftButton, INPUT_PULLUP);
  pinMode(rightButton, INPUT_PULLUP);
  pinMode(stepPin,OUTPUT);
  pinMode(dirPin,OUTPUT);
  snippers.attach(servo);
  snippers.write(openAngle);
  if (!digitalRead(rightButton)){
    if(state == 5){
      state = 0;
    else{
      state += 1;
    delay(200);
    lcd.clear();
  if (!digitalRead(leftButton) && state > 0 && state < 4){
    state -=1;
    delay(200);
    lcd.clear();
  switch (state){
    case 0:
      homeScreen();
    case 1:
       chooseWireLength();
    case 2:
      chooseWireQuantity();
    case 3:
      confirm();
    case 4:
      currentlyCutting();
    case 5:
      finishedCutting();
void homeScreen(){
  lcd.setCursor(0, 0);
  lcd.print("WIRE CUTTER");
  lcd.setCursor(11, 1);
  lcd.print("NEXT>");
  delay(100);
void chooseWireLength(){
  wireLength = changeValue(wireLength);
  //clear LCD if required
  if(previousWireLength != wireLength){
    lcd.clear();
    previousWireLength = wireLength;
  //Display information on LCD
  lcd.print("LENGTH:" + (String)wireLength + "mm");
  displayNavigation();
void chooseWireQuantity(){
  wireQuantity = changeValue(wireQuantity);
  if(previousWireQuantity != wireQuantity){
    lcd.clear();
    previousWireQuantity = wireQuantity;
  lcd.print("QUANTITY:" + (String)wireQuantity);
void confirm(){
  lcd.print((String)wireLength + "mm x " + (String)wireQuantity + "pcs");
  lcd.setCursor(0, 1);
  lcd.print("<BACK");
  lcd.setCursor(10, 1);
  lcd.print("START>");
  delay(100);
void currentlyCutting(){
  lcd.print((String)0 + "/" + (String)wireQuantity);
  lcd.print("???s");
  int stepsToTake = (int)wireLength/mmPerStep;
  for(int i = 0; i < wireQuantity; i++){
    unsigned long timeForOneCycle = millis();
    digitalWrite(dirPin,HIGH);
    for(int x = 0; x < stepsToTake; x++) {
      digitalWrite(stepPin,HIGH);
      delayMicroseconds(500);
      digitalWrite(stepPin,LOW);
    lcd.print((String)(i+1) + "/" + (String)wireQuantity);
    snippers.write(closedAngle);
    delay(600);
    delay(600);
    unsigned long timeRemaining = ((millis() - timeForOneCycle)*(wireQuantity - (i+1)))/1000;
    lcd.print((String)timeRemaining + "s    ");
  wireLength = 0;
  wireQuantity = 0;
  state = 5;
void finishedCutting(){
  lcd.clear();
  lcd.print("CUTTING COMPLETE");
  lcd.print("NEXT>");
  delay(100);
int changeValue(int currentValue){
  if (!digitalRead(upButton)) {
    delay(100);
    currentValue += incrementSpeed;
  if (!digitalRead(downButton)) {
    if(currentValue - incrementSpeed >= 0){
      delay(100);
      currentValue -= incrementSpeed;
    else{
      currentValue = 0;
  if (!digitalRead(downButton) && !digitalRead(upButton)){
    incrementSpeed = 1;
  return currentValue;
void displayNavigation(){
  lcd.print("<BACK");
  lcd.print("NEXT>");
  delay(100);
septillion
Hi, welcome. Please read How to use the forum. Especially the part about code tags and what YOU have tried so far.
But as an answer:
cm = mm / 10
Use fricking code tags!!!!
I want x => I would like x, I need help => I would like help, Need fast => Go and pay someone to do the job...
NEW Library to make fading leds a piece of cake
https://github.com/septillion-git/FadeLed
sdzafar
But as an answer:
cm = mm / 10
Thanks for reply
I want to convert mm to cm in code.
septillion
So, what makes that difficult in code?
Code: [Select]
cm = mm / 10;[/code
is completely valid code.
So start by changing you post to have code tags. Next, tell us what you tried an why you think that did not work.
UKHeliBob
Quote
Given a measurement in mm how would you convert it to cm using pencil and paper, or even a calculator ?
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
david_2018
Are you wanting to have the length in whole cm / inches, or do you want to allow fractional amounts?
If only whole numbers, just change all the display text from "mm" to the appropriate "cm" or "in",
then in the wire cutter section, change the line that calculates the stepper motor steps:
Code: [Select]
//original code
 int stepsToTake = (int)wireLength / mmPerStep;
//code for wireLength in cm
 int stepsToTake = (int)((wireLength * 10) / mmPerStep;)
//code for wireLength in inches
 int stepsToTake = (int)((wireLength * 25.4) / mmPerStep;)
JaBa
The US has been "converting to the metric system within 10 years" for 50 years now and we have to explain how to convert mm to cm...  But everyone is expected to know how many feet are in a mile?
Robin2
The official definition of an inch is 25.4 mm
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
JCA79B
#8
Mar 24, 2019, 06:56 am Last Edit: Mar 24, 2019, 07:00 am by JCA79B
Quote
But its really closer to:
1 / 0.03937 = 25.400050800102   :smiley-grin:
Robin2
Not according to my Physics text book
Quote
1 inch = 2.54 centimetres (exactly)
...R
sdzafar
Code: [Select]
//original code
Thank you for quick understanding, and thanks for your help it perfectly works.
   just one thing is here, an input value is 2inch, output wire size is 1.9inch (as an attachment image)
TomGeorge
Your wireLength variable is an int,
Try this, it may fix the problem.
Code: [Select]
 int stepsToTake = (int)(((float)wireLength * 10.0) / mmPerStep;)
 int stepsToTake = (int)(((float)wireLength * 25.4) / mmPerStep;)
Tom... :)
Everything runs on smoke, let the smoke out, it stops running....
david_2018
Code: [Select]
Tom... :)
If that does not fix the problem, did you try the original program to verify the length using mm?  Its possible your value for mmPerStep may need to be adjusted.  The picture showed two slightly different lengths of wire, if you are getting inconsistent lengths the wire may be slipping in the feeder.
