Topic: Matrix problem (Read 5955 times) previous topic - next topic
PaulRB
actually, when everything is 0 the matrix is on
Oh, yeah.
The evening or this weekend, will try to get you another step forward. Maybe we can display a fixed image.
bogdan666
no problem, i appreciate it.
PaulRB
i am prepared to learn every line of the code
For the code that is working now, are there any lines you do not understand or have questions about?
bogdan666
no, it was very clear because you started with a big delay between the rows, so i saw each change with "my own eyes"
PaulRB
#64
Apr 13, 2019, 11:46 am Last Edit: Apr 13, 2019, 11:50 am by PaulRB
OK, lets add a few more lines of code:
Code: [Select]
#include <SPI.h>
#define LATCH 10
#define MULTIPLEX_PERIOD 2
SPISettings shiftRegister(10000000UL, LSBFIRST, SPI_MODE0);
unsigned int image[8] = {
  0b0000000000001000,
  0b0000000000001100,
  0b0000000000001110,
  0b1111111111111111,
  0b0000000000001110,
  0b0000000000001100,
  0b0000000000001000,
  0b0000000000000000
  SPI.begin(); //Start up the SPI hardware
  SPI.beginTransaction(shiftRegister); //Prepare to send data to shift registers
  pinMode(LATCH, OUTPUT);
void multiplexDisplay() {
  //"static" means these variables do not loose their value when multiplexDisplay() ends
  static byte currRow; //the row, 0 to 7, of the matrix that is currently lit
  static unsigned long lastUpdate; //time when this row was lit
  unsigned long millisNow = millis(); //Get time now
  if (millisNow - lastUpdate >= MULTIPLEX_PERIOD) { //Is it time to light next row of matrix?
    lastUpdate = millisNow; //Record time this row was lit
    SPI.transfer(1 << currRow); //Send a byte indicating which row to light
    SPI.transfer(~lowByte(image[currRow])); //Send the required pattern for this row of the matrix
    SPI.transfer(~highByte(image[currRow]));
    digitalWrite(LATCH, LOW);
    digitalWrite(LATCH, HIGH); //Latch the data into the shift register outputs
    if (currRow++ > 7) currRow = 0; //Get ready to light next row of matrix
  multiplexDisplay();
bogdan666
The arrow pointing to the left is displaying correctly, no flickering, and also, now because you change to lsbfirst the leds light up at 1 instead of 0 ?
PaulRB
Ah. The arrow was supposed to point right, as it looks in the code. Change the LSBFIRST back to MSBFIRST and swap the highByte() and lowByte() functions.
What changed the LEDs to light up with a 1 is the "~" operator. It means "binary not" and reverses 0s & 1s.
bogdan666
#67
Apr 13, 2019, 06:20 pm Last Edit: Apr 13, 2019, 07:09 pm by bogdan666
wait, it's pointing right, i just mixed them up sorry.
LE: in my excitement of seeing an arrow on my matrix, after confusing right and left, i noticed another thing, the code starts from first row, but my first row is off, so i think that the arrow is up side down.
PaulRB
Try this change:
Code: [Select]
    SPI.transfer(128 >> currRow); //Send a byte indicating which row to light
bogdan666
yes, it works, the leds are on for every 1 in the code, but you have to explain what happened and the changes with lsb msb and the last change.
PaulRB
#70
Apr 13, 2019, 09:09 pm Last Edit: Apr 13, 2019, 09:11 pm by PaulRB
This page will tell you about the << and >> operators.
This page will tell you about MSBFIRST and LSBFIRST.
bogdan666
so in a very short way, both of these problems tell you the "direction" from where the bits are being read, right ?
PaulRB
LSBFIRST & MSBFIRST do, yes.
The << & >> operators move bits around inside a variable by shifting them right or left by one or more places.
bogdan666
PaulRB
#74
Apr 14, 2019, 12:03 pm Last Edit: Apr 14, 2019, 12:03 pm by PaulRB
Shall we try a little scrolling next?
Code: [Select]
#include <SPI.h>
#define LATCH 10
#define SCROLL_PERIOD 200
SPISettings shiftRegister(10000000UL, MSBFIRST, SPI_MODE0);
  0b0000000000001000,
  0b0000000000001100,
  0b0000000000001110,
  0b1111111111111111,
  0b0000000000001110,
  0b0000000000001100,
  0b0000000000001000,
  0b0000000000000000
  //"static" means these variables does not loose their value when multiplexDisplay() ends
    SPI.transfer(~highByte(image[currRow])); //Send the required pattern for this row of the matrix
void scrollDisplay() {
  static unsigned long lastUpdate; //time when matrix was last scrolled
  if (millisNow - lastUpdate >= SCROLL_PERIOD) { //Is it time to scroll the matrix?
    lastUpdate = millisNow; //Record time the matrix was scrolled
    for (byte row = 0; row < 8; row++) {
      byte savedBit = bitRead(image[row], 15);
      image[row] <<= 1;
      bitWrite(image[row], 0, savedBit);
  multiplexDisplay();
  scrollDisplay();
As before, please let me know what you see, I can't test this. Also not sure which direction it will scroll! And as always, please read each line and ask about anything you don't understand.
