Topic: How can I communicate wirelessly without IR? (Read 3452 times) previous topic - next topic
TECH GEEK
I'm hoping to use radio waves created via a 555 timer circuit on a breadboard, to send a variable frequency to be sensed via an antenna on my Arduino Mega 1280...
But i'm unsure how to create a radio transceiver & receiver using common components, no IC's besides 555's and other very common IC's....
also I don't even know how an radio antenna system works.
(I DO know how an IR remote communicates with a TV, and I assume radios work on similar principles? Right?)
can anyone help me with these circuits?
As always... Thanks for posting!!!
CrossRoads
You an use RF instead.
Principles are not really the same. IR is just light turning off & on, just at a wavelength you can't see. The receiver sees flashes of light, and  outputs a high/low signal accordingly.
RF has to transmit  a burst of radio waves that the digital signal is encoded onto. The receiver has to sync up to the carrier frequency, and extract the digital info from it.
You can buy an RF TX & Rx pair for <$10 with 17cm piece of wirewrap wire for an antenna, you will not be able to duplicate that performance with 555 timers.
Need to find comparable versions of these:
http://www.sparkfun.com/products/8950
http://www.sparkfun.com/products/8946
Maybe these
http://www.laipac.com/easy_434a_eng.htm
compuslave
In many ways the two are the same, though. They are both forms of electromagnetic radiation, just at different wavelengths. They are both digital signals, ie ons and offs. The rf is just more of a moving target since it's carrier frequency can vary. Its a trip to think about how all of our devices, our phones and wifi equipped laptops and all that stuff is spewing out this radiation all the time and its exactly like the light we see, just at a different wavelength. I often imagine how bright a cell phone tower must look if I could see that wavelength of 'light'.
My head just exploded. I should probably clean up this mess.
Oh, nevermind, one kleenex got it.
CrossRoads
Sure the same, but operationally very different.
For IR, you just send current at low switching frequency thru an LED, and receive it with simple phototransistor. Operation is limited to line of sight (or bouncing off a wall or ceiling sometimes). Can even get your ipod to send the IR, its pretty slow.
For RF, you replace the LED & phototransistor with complete modules that must end up sync'ed or you don't get meaningful data out. And it will work 100m away - IR can't do that.
TECH GEEK
Yes I could just buy some pre-made device that takes care of the building and most of the testing...
But what fun would there be in that???
Not to be rude, but the reason I want to use the "555+commonParts+ Breadboard" approach is for the challenge of that method...
But if it is not plausible to use this approach, then how am I ever going to learn about electronics?
ps: if i seem to be rude above, which i'm trying not to be, it may just be that it's 3:00AM and I can't get to sleep at all tonight...
Grumpy_Mike
It is not legal to make your own transmitters unless you are licences to do so. Your best bet is to get yourself a ham licence, that is how you learn but not before you have to prove you know the fundamentals of what you are doing.
TECH GEEK
CrossRoads
Ok, I googled 555 AM transmitter and got quite a few hits,
here's one example
http://www.youtube.com/watch?v=gASzqSyHzyM
so transmitting seems doable.
Here's a receiver also
http://m8051.blogspot.com/2011/02/am-radio-receiver-using-555-simple-rf.html
Do some searching on 555 design contest and see what you can come up with.
Grumpy_Mike
Yes but it is still not legal.
@TECH GEEK What country are you in?
CrossRoads
I would think transmission power & frequency would be a factor in that Mike.
In the US there are bands where low power transmissions are allowed.
http://en.wikipedia.org/wiki/Low-power_broadcasting
Not many, but AM looks like one of them if this data is correct.
Grumpy_Mike
Quote
Yes but in the UK and many other countries there are no such allowances and any form of RF transmission on a home built set is legal no matter what the power and frequency.
Especially once you start modulating such a transmitter you have the capacity to cause interference over a wide band, not just the frequency you are using.
compuslave
Nice link, CrossRoads!
I didn't mean to imply that ir and rf were functionally the same. I only went off on a tangent because this thread got me thinking about all the invisible light around us.
:headexplodes:
TECH GEEK
Back...
Yes  live in the USA, State = PA...
also I  agree with crossroad about the power of the transmission. If my professional grade Remote Control (R/C) truck can't be controlled farther than 500 feet, than I assume that Video crossroads provided should be OK?  Also I have seen hundreds of educational NPN-based radio station kits sold where I live...
CrossRoads
As long as you're no stronger than baby monitor power and not on a frequency that's bothering anyone, you'd probably be okay.
