Topic: Simon Says project (Read 785 times) previous topic - next topic
Lilrex
ok so my buttons are working... for some reason the leds are staying on and turning off when i press the button down but either way it is working.
but when i call the userIn() function the code just ignores my checks and turns on the lights, prints the serial line and then progresses down.
Code: [Select]
   for (int i = 0;  i < 4;)
  while(buttonState !=4)
    if(buttonState != 4 && BB == LOW)
I am trying to "pause" the program and await the users button selection, and then add those button selections to an array so i can compare them afterwards.
I know arduino cannot be paused thats why it is in " "  but i need something similar.
cattledog
Quote
When you enter the function, add serial print outs of the variables used in the conditional tests.
Code: [Select]
What is the value of BB? If the switch is wired correctly, and the input pin is set to INPUT_PULLUP mode, the value of BB can not be low if it is not pressed.
I think you have some extra brackets in userIn(), but I don't think that is what is causing your issue.
Quote
Why are the led's wired so that one leg is common with a button pin leg? I would suggest moving the leds to a different place on the breadboard where they are independent of the buttons..
wolframore
So much easier when we can see the wiring... he's right you need the get the LED's away from the same row as the buttons.
Bad Boys Race Our Young Girls But Violet Generally Wins - Get Some Now :) - ELI ICE man
