Topic: Serial communication Python to arduino (Read 269 times) previous topic - next topic
vova1989
Hello,
I have a python code that i get information that i need from rplidar a1m8.
the data i need is angle and distance.
I need a help to get this data on arduino and use it.
Python code:
import sys
import time
from rplidar import RPLidar
import serial
import struct
arduino = serial.Serial('com6', 115200)
angleoffset = 0
PORT_NAME = 'COM5'  # this is for the Lidar
def run():
    '''Main function'''
    lidar = RPLidar(PORT_NAME)
    lidar.start_motor()
    time.sleep(1)
    info = lidar.get_info()
    print(info)
    try:
        print('Recording measurments... Press Crl+C to stop.')
        try:
            for measurment in lidar.iter_measurments():
                if (measurment[2] > 0 and measurment[2] < 360):
                    if (measurment[3] < 2000 and measurment[3] > 100):
                        angle = measurment[2]
                        distance = measurment[3]
                        print("Angle: ", angle - angleoffset)
                        print("Distance: ", distance)
        except KeyboardInterrupt:
            print('Stopping.')
        print('Stopping.')
    lidar.stop()
    lidar.stop_motor()
    lidar.disconnect()
if __name__ == '__main__':
    run()
Robin2
This simple Python - Arduino demo should help get you started.
See also Serial Input Basics - simple reliable ways to receive data.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
