Topic: Difference between interrupt pin? (Read 220 times) previous topic - next topic
Bamanio
I followed this Wind Speed project:
http://forcetronic.blogspot.com/2016/12/measuring-wind-speed-with-anemometer.html
On the Due, I expected to choose whatever interrupt Pin but found out that using PIN 2 gives totally different results than using PIN 8.
aren't they suppose to be the same on Due?
thanks
ard_newbie
#1
Mar 28, 2019, 08:27 pm Last Edit: Mar 29, 2019, 05:18 am by ard_newbie
AFAIk there should not be any difference, both are Schmitt trigger pins (page 12, Sam3x datasheet).
Did you try with pull down resistors on both ?
pert
What is the difference you're seeing? Are you saying you get different wind speed readings depending on which pin is used?
