Topic: Can't get 0022 to run on Ubuntu 11.04 (Read 1 time) previous topic - next topic
sspence65
I have run the following:
sudo apt-get remove brltty brltty-x11
sudo apt-get install openjdk-6-jre
sudo apt-get install avr-libc avrdude binutils-avr gcc-avr
I downloaded the 32 bit version of 0022, e4xtracted it, set it to executable, and when I run it in terminal, I get the sketch folder set dialog, then the following:
java.lang.UnsatisfiedLinkError: /home/owner/Desktop/arduino-0022/lib/librxtxSerial.so: /home/owner/Desktop/arduino-0022/lib/librxtxSerial.so: wrong ELF class: ELFCLASS32 (Possible cause: architecture word width mismatch) thrown while loading gnu.io.RXTXCommDriver
Exception in thread "main" java.lang.UnsatisfiedLinkError: /home/owner/Desktop/arduino-0022/lib/librxtxSerial.so: /home/owner/Desktop/arduino-0022/lib/librxtxSerial.so: wrong ELF class: ELFCLASS32 (Possible cause: architecture word width mismatch)
   at java.lang.ClassLoader$NativeLibrary.load(Native Method)
   at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1750)
   at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1675)
   at java.lang.Runtime.loadLibrary0(Runtime.java:840)
   at java.lang.System.loadLibrary(System.java:1047)
   at gnu.io.CommPortIdentifier.<clinit>(CommPortIdentifier.java:83)
   at processing.app.Editor.populateSerialMenu(Editor.java:957)
   at processing.app.Editor.buildToolsMenu(Editor.java:694)
   at processing.app.Editor.buildMenuBar(Editor.java:479)
   at processing.app.Editor.<init>(Editor.java:201)
   at processing.app.Base.handleOpen(Base.java:699)
   at processing.app.Base.handleOpen(Base.java:664)
   at processing.app.Base.handleNew(Base.java:561)
   at processing.app.Base.<init>(Base.java:301)
   at processing.app.Base.main(Base.java:190)
Steve Spence - KK4HFJ
mellis
Are you sure you have the 32-bit version of Ubuntu?  Did you try the 64-bit version of Arduino?
sspence65
32 bit Ubuntu, 32 bit Arduino. Now installing the 64 bit version of both.
sspence65
both verified 64 bit. all is now working. must have gotten a mixed set.
