Topic: Lock using static libraries *.a (Read 378 times) previous topic - next topic
lululuv1
Hello,
I would like to link a static library into my Arduino project. I have tested it for SAMD and AVR respectively ( Arduino Uno et Arduino Zero)
I have already read this topics:
https://arduino.stackexchange.com/questions/57891/how-to-use-a-precompiled-library-in-a-project-with-arduino-ide
https://github.com/arduino/Arduino/wiki/Arduino-IDE-1.5:-Library-specification#libraryproperties-file-format
https://github.com/arduino/Arduino/issues/4336
I follow the instruction in order to add static library, then I can see it in the Contributed library (attached file)
Here is the source code of my compiled library :
Code: [Select]
int foo(void) {
  return 1;
Then, I create a library using ar tool.
I create a repo called foo which include
* library.properties
* and a repo src as below:
-/src
---foo.h
---/{architecture_mcu_name}
-----libfoo.a
Code: [Select]
name=foo
version=0.0.1
author=lululuv1
maintainer=foo <foo@gmail.com>
sentence=
paragraph=
category=Uncategorized
url=
architectures=*
precompiled=true
ldflags=-lfoo
My foo.h contain the function prototype : int foo(void);
FInally I create the ino project, include the library....
Code: [Select]
#include <foo.h>
  int foo_value = foo();
  Serial.print("FOOFOOFOOFOOF");
Link with the library is done because if I want to link a libfoo.a from a dismatch architecture I got an error.
Hence, there is no compilation error, no link error but when i call the function foo(); I am lock, the print FOOFOOFOOFOO is never done.
Any idea ?
Thank you
PS: this is a simple example in order to reproduce the problem, can be done with avr-gcc or arm-none-eabi-gcc
