Topic: Spike in FFT results (Read 194 times) previous topic - next topic
DrDeform
I have an Arduino hooked directly up to this mic:
https://www.adafruit.com/product/1713?gclid=CjwKCAjwp_zkBRBBEiwAndwD9bhbwr9779j7eWlLUH75TkSD6b6axYE73z9Z3Q-dP8y1nImqWGO0hRoC_wIQAvD_BwE
And using code provided here:
https://www.norwegiancreations.com/2017/08/what-is-fft-and-how-can-you-implement-it-on-an-arduino/
I am trying to perform FFT on incoming audio from the mic. Now the problem is I keep getting huge spikes at the lower frequencies when there is little noise around the mic. These are usually in the first and second bins and are too high to be considered noise. I have attached images of the Serial Monitor & Plotter for reference.
What could be causing this? All the other bins seem to be working correctly.
Grumpy_Mike
Quote
The first bin is the DC bias and the other three look like mains interference.
MarkT
Thats just the DC peak - unless you subtract the DC offset from your signal you'll always get some DC,
and normally you can completely ignore it.
It spills into adjecent bins in a manner determined by the windowing function chosen, which from your
link appears to be a Hamming window.
