Hello,
I have a problem while connecting arduino UNO with the bluetooth module Xm-15b and the driver LN298.
I am making a 2 wheels robot controlled by bluetooth.
The problem is that when i am connected to the computer port ("COM4"), it works; but if i use the 9v battery instead of the computer, although everything turn on, the connection with my cellphone (using BluetoothSerialController.apk) doesnt work when i reconnect it to the module.
the code is the following:
int in1 = 7;
int in2 = 6;
int in3 = 5;
int in4 = 4;
pinMode (in1,OUTPUT);
pinMode (in2,OUTPUT);
pinMode (in3,OUTPUT);
pinMode (in4,OUTPUT);
if (Serial.available()>0)
char nodato = Serial.read();
char dato = char (nodato);
if (dato == '0')
digitalWrite (in1,LOW);
digitalWrite (in2,HIGH);
digitalWrite (in3,HIGH);
if (dato == '1')
digitalWrite (in1,HIGH);
digitalWrite (in2,LOW);
if (dato == '2')
if (dato == '3')
digitalWrite (in3,LOW);
if (dato == '4')
the connections are these:
xm-15b:
