Topic: Examples (Read 1 time) previous topic - next topic
TomasRoj
Hey, when you started with arduino, what was best example project that helped you most?
AWOL
Blink without delay.
DBMcDonald
Your BasicsLibrary version, blinkNoDelay(), generates a compiler error and even after the compiler error is fixed it cannot possibly work.
Do you know why?
AWOL
Do you know why?
I don't even know what the BasicsLibrary is.  :smiley-confuse:
larryd
Master all of them.
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
Robin2
I don't see that as a realistic question. It all depends on the project you are trying to implement.
For example there would be little point in learning all about I2C if your project does not need it. Indeed I never used it until about 2 weeks ago.
Experience counts for a lot. Every time you run into an error and figure out the problem your stock of knowledge grows.
Back in the day there were monthly magazines with lots of program examples for things like the Commodore 64, the Sinclair Spektrum and the original MSDOS IBM PC. I learned a great deal from reading the magazines long before I could afford a Spektrum. IMHO the same learning can be achieved now by reading lots of Forum threads. You probably won't remember all you read but when you see a problem your brain will say "didn't I read about something similar to this ? - now, where was it?"
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
TomasRoj
#6
Apr 01, 2019, 06:05 pm Last Edit: Apr 01, 2019, 06:08 pm by TomasRoj
My library for beginners. Hated by whole arduino community...
AWOL
Never heard of it, so "hated by whole arduino community" is grossly inaccurate.
Paul_KD7HB
TomasRoj
have a look here: http://forum.arduino.cc/index.php?topic=606830.0
AWOL
#11
Apr 01, 2019, 06:14 pm Last Edit: Apr 01, 2019, 06:16 pm by AWOL
OK, so now I've seen it, I dislike it, but I wouldn't go so far as to say "hate".
I don't see what you're trying to achieve.
Your blink without delay simply won't work; it didn't seem worth looking at anything else.
TomasRoj
No just wanted to know what basicslibrary means. I fixed it now.
AWOL
#13
Apr 01, 2019, 06:21 pm Last Edit: Apr 01, 2019, 06:22 pm by AWOL
Not on the version I'm looking at. (just refreshed)
Hint:
Code: [Select]
unsigned long previousMillis = 0; // will store last time LED was updated
TomasRoj
So what about to try fix it together?
We can make new thread.
