Topic: How to use I2C to call accelerometer data from 2 Grove IMU 9DoF v2.0 Sensors? (Read 346 times) previous topic - next topic
ChrisSimons
Hi all,
I'm currently working on a project to calculate and output the angle made at the knee by the upper and lower leg. I am doing this by using Grove IMU 9Dof v2.0 sensors (library here: https://raw.githubusercontent.com/SeeedDocument/Grove-IMU_9DOF_v2.0/master/res/Grove_IMU_9DOF_9250.zip ) one on the thigh and one on the shin and using the angles created between the sensor and the vertical axis to calculate the angle of each limb.
I currently have data outputting from 1 sensor, but I'm unsure how to get data from both simultaneously. I have no experience with I2C before and dont know how to code the 2 different sensors.
Below is the code I currently have, which reads data from only 1 sensor.
I used the example code that came with the library so there may be redundent parts of the code.
I really have 2 questions, how to alter this code to allow for reading from 2 sensors (addresses of 0x68 and 0x69), and how to change the code to get rid of extra variables that aren't used.
Any help or advice would be greatly appreciated!
Code: [Select]
#include "Wire.h"
#include "Math.h"
#include "I2Cdev.h"
#include "MPU9250.h"
MPU9250 accelgyro;
I2Cdev I2C_M;
uint8_t buffer_m[6];
int16_t ax, ay, az;
int16_t gx, gy, gz;
int16_t mx, my, mz;
float heading;
float tiltheading;
float Axyz[3];
float Gxyz[3];
float Mxyz[3];
float angle[3];
//#define sample_num_mdate  5000
  // join I2C bus
  Wire.begin();
  // initialise serial communication
  // 38400 chosen for high baud rate
  Serial.begin(38400);
  accelgyro.initialize();
 getAccel_Data();
 getAngle();
 Serial.println(angle[1]);
 delay(50);
void getAccel_Data(void)
  accelgyro.getMotion9(&ax, &ay, &az, &gx, &gy, &gz, &mx, &my, &mz);
  Axyz[1] = (double) ay / 16384;
void getAngle(void)
  getAccel_Data();
  float angley = acos(Axyz[1]/1);
  angle[1] = (double) 180 * angley / PI;
PaulS
If you have more than one I2C device, you need to change the I2C address of one of them. Does the MPU9050 allow you to do that? If so, have you done that? If you have, then you need to create an instance of the MPU9050 with a different constructor, where you can define the address to use.
jremington
Quote
You can't. You have to read one sensor, then the other.
You will have to change the I2C device address of one of the sensors. To do that, connect the module AD0 pin to 3.3V, and that device will respond to address 0x69.
ChrisSimons
I have changed the address of one by soldering a conection to change it as instructed the way I currently have the sensors wired as follows SCL to A5, SDA to A4, GND to GND and VCC to 3.3V. I should point out I am using the Arduino Nano board.
How do I do this?
PaulS
Quote
How do I do this?
Beats me. You didn't post a link to the library you are using, so I can't tell you how to use it.
ChrisSimons
Apologies I thought I had, here are the links to where I got the library from
http://wiki.seeedstudio.com/Grove-IMU_9DOF_v2.0/
PaulS
Code: [Select]
class MPU9250 {
    public:
        MPU9250();
        MPU9250(uint8_t address);
There are two constructors. To use the default address,
Code: [Select]
   MPU9050 defaultAddress;
To use an alternate address:
Code: [Select]
   MPU9050 otherAddress(theOtherAddress);
Then, call initialize() on both instances. To read from either one, use getMotion9() on the appropriate instance.
ChrisSimons
I believe the addresses work because I got no error messages for those, thank you for that!
I don't think I've done the rest of it right though, I have the initialize as:
Code: [Select]
initialize(0x69);
initialize(0x68);
I also tried
Code: [Select]
int(0x69);
I tried google and the search function on this forum to find an answer but I don't really know what to search to find the right answer and couldn't find anything about initialize().
I got the following error messages if they are helpful.
Code: [Select]
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Arduino Nano, ATmega328P"
Sensor_sketch_5:9:11: error: expected constructor, destructor, or type conversion before '(' token
initialize(0x69);
Sensor_sketch_5:10:11: error: expected constructor, destructor, or type conversion before '(' token
initialize(0x68);
D:\Chris\Documents\Arduino\Sensor_sketch_5\Sensor_sketch_5.ino: In function 'void getAccel_Data()':
Sensor_sketch_5:50:28: error: no matching function for call to 'MPU9250::getMotion9(int)'
  accelgyro.getMotion9(0x69);
In file included from D:\Chris\Documents\Arduino\Sensor_sketch_5\Sensor_sketch_5.ino:4:0:
D:\Chris\Documents\Arduino\libraries\Grove_IMU_9DOF_9250/MPU9250.h:586:14: note: candidate: void MPU9250::getMotion9(int16_t*, int16_t*, int16_t*, int16_t*, int16_t*, int16_t*, int16_t*, int16_t*, int16_t*)
        void getMotion9(int16_t* ax, int16_t* ay, int16_t* az, int16_t* gx, int16_t* gy, int16_t* gz, int16_t* mx, int16_t* my, int16_t* mz);
D:\Chris\Documents\Arduino\libraries\Grove_IMU_9DOF_9250/MPU9250.h:586:14: note:   candidate expects 9 arguments, 1 provided
Sensor_sketch_5:54:6: error: redefinition of 'void getAccel_Data()'
void getAccel_Data(void)//0x68
D:\Chris\Documents\Arduino\Sensor_sketch_5\Sensor_sketch_5.ino:48:6: note: 'void getAccel_Data()' previously defined here
void getAccel_Data(void)//0x69
Sensor_sketch_5:56:28: error: no matching function for call to 'MPU9250::getMotion9(int)'
  accelgyro.getMotion9(0x68);
D:\Chris\Documents\Arduino\Sensor_sketch_5\Sensor_sketch_5.ino: In function 'void getAngle()':
Sensor_sketch_5:61:21: error: too many arguments to function 'void getAccel_Data()'
  getAccel_Data(0x69);
D:\Chris\Documents\Arduino\Sensor_sketch_5\Sensor_sketch_5.ino:48:6: note: declared here
Sensor_sketch_5:66:6: error: redefinition of 'void getAngle()'
void getAngle(void) //0x68
D:\Chris\Documents\Arduino\Sensor_sketch_5\Sensor_sketch_5.ino:59:6: note: 'void getAngle()' previously defined here
void getAngle(void) //0x69
Sensor_sketch_5:68:21: error: too many arguments to function 'void getAccel_Data()'
  getAccel_Data(0x68);
Using library Wire at version 1.0 in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire
Using library Grove_IMU_9DOF_9250 in folder: D:\Chris\Documents\Arduino\libraries\Grove_IMU_9DOF_9250 (legacy)
exit status 1
PaulS
Quote
I don't think I've done that right
initialize() does not take an address. The instance KNOWS the address, if you have defined the instances correctly.
If you have two sensors, with addresses 0x68 (the default address) and 0x69, you should have:
Code: [Select]
MPU9050 One;
MPU9050 Two(0x69);
   One.initialize();
   Two.initialize();
   One.getMotion9(&ax, &ay, &az, &gx, &gy, &gz, &mx, &my, &mz);
   // Use the data from One
   Two.getMotion9(&ax, &ay, &az, &gx, &gy, &gz, &mx, &my, &mz);
   // Use the data from Two
ChrisSimons
I copied that formatting
Code: [Select]
MPU9250 One;
MPU9250 Two(0x69);
One.initialize();
Two.initialize();
but got the following error message
Code: [Select]
Sensor_sketch_5:9:1: error: 'One' does not name a type
 One.initialize();
Sensor_sketch_5:10:1: error: 'Two' does not name a type
 Two.initialize();
I couldn't really understand the solutions I found online
jremington
ChrisSimons
Apologies for the delay,
Here is the code in its current state
Code: [Select]
#include "Wire.h"
#include "Math.h"
#include "I2Cdev.h"
MPU9250 One;
MPU9250 Two(0x69);
One.initialize();
Two.initialize();
MPU9250 accelgyro;
I2Cdev I2C_M;
int16_t ax, ay, az;
int16_t gx, gy, gz;
int16_t mx, my, mz;
float heading;
float tiltheading;
float Axyz[3];
float Gxyz[3];
float Mxyz[3];
float angle[3];
  // join I2C bus
  Wire.begin();
 getAccel_Data();
 getAngle();
 delay(50);
void One.getAccel_Data(void)//0x68
void Two.getAccel_Data(void)//0x69
  One.getAccel_Data();
  Two.getAccel_Data();
and here are the error messages
Code: [Select]
 One.initialize();
 Two.initialize();
D:\Chris\Documents\Arduino\Sensor_sketch_5\Sensor_sketch_5.ino: In function 'void loop()':
Sensor_sketch_5:42:16: error: 'getAccel_Data' was not declared in this scope
  getAccel_Data();
D:\Chris\Documents\Arduino\Sensor_sketch_5\Sensor_sketch_5.ino: At global scope:
Sensor_sketch_5:48:9: error: expected initializer before '.' token
Sensor_sketch_5:57:9: error: expected initializer before '.' token
Sensor_sketch_5:64:7: error: 'class MPU9250' has no member named 'getAccel_Data'
Sensor_sketch_5:69:6: error: redefinition of 'void getAngle()'
D:\Chris\Documents\Arduino\Sensor_sketch_5\Sensor_sketch_5.ino:62:6: note: 'void getAngle()' previously defined here
Sensor_sketch_5:71:7: error: 'class MPU9250' has no member named 'getAccel_Data'
exit status 1
jremington
Put these in setup()
Code: [Select]
One.initialize();
Two.initialize();
Remove this line, and remove the corresponding initialize() in setup()
Code: [Select]
MPU9250 accelgyro;
Code: [Select]
ChrisSimons
That seemed to fix the initialization part, thank you for that.
I'm still having errors with the looped part of the code however, code:
Code: [Select]
  One.initialize();
  Two.initialize();
  // join I2C bus
  Wire.begin();
 getAngle();
 delay(50);
void One.getAngle(void) //0x68
void Two.getAngle(void) //0x69
and errors
Code: [Select]
Sensor_sketch_5:41:6: error: 'class MPU9250' has no member named 'getAccel_Data'
Sensor_sketch_5:42:6: error: 'class MPU9250' has no member named 'getAccel_Data'
Sensor_sketch_5:43:11: error: 'getAngle' was not declared in this scope
  getAngle();
Sensor_sketch_5:62:9: error: expected initializer before '.' token
Sensor_sketch_5:69:9: error: expected initializer before '.' token
exit status 1
jremington
The error message is self explanatory.
Check which function calls are available in the library you included. getAccel_Data is not one of them.
