Topic: Using MKR 1400 without Arduino IDE (Read 438 times) previous topic - next topic
amirf
This may be a basic question but I need help to learn how to use MKR1400 without Arduino IDE. The following code only runs when I open Arduino and open the logger window. I want it to run when connecting to any power source.
Code: [Select]
  Web client
 This sketch connects to a website through a MKR GSM 1400 board. Specifically,
 this example downloads the URL "http://www.example.org/" and
 prints it to the Serial monitor.
 Circuit:
 * MKR GSM 1400 board
 * Antenna
 * SIM card with a data plan
 created 8 Mar 2012
 by Tom Igoe
// libraries
#include <MKRGSM.h>
#include "arduino_secrets.h"
// Please enter your sensitive data in the Secret tab or arduino_secrets.h
// PIN Number
const char PINNUMBER[]     = SECRET_PINNUMBER;
// APN data
const char GPRS_APN[]      = SECRET_GPRS_APN;
const char GPRS_LOGIN[]    = SECRET_GPRS_LOGIN;
const char GPRS_PASSWORD[] = SECRET_GPRS_PASSWORD;
// initialize the library instance
GSMClient client;
GPRS gprs;
GSM gsmAccess;
// URL, path and port (for example: example.org)
char server[] = "api.pushingbox.com";
char path[] = "/pushingbox?devid=v5CEB031065887B8&sensorValue=55";
int port = 80; // port 80 is the default for HTTP
  // initialize serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.println("Starting Arduino web client.");
  // connection state
  bool connected = false;
  // After starting the modem with GSM.begin()
  // attach the shield to the GPRS network with the APN, login and password
  while (!connected) {
    if ((gsmAccess.begin(PINNUMBER) == GSM_READY) &&
        (gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD) == GPRS_READY)) {
      connected = true;
      Serial.println("Not connected");
  Serial.println("connecting...");
  // if you get a connection, report back via serial:
  if (client.connect(server, port)) {
    Serial.println("connected");
    // Make a HTTP request:
    client.print("POST ");
    client.print(path);
    client.println(" HTTP/1.1");
    client.print("Host: ");
    client.println(server);
    client.println("Connection: close");
    client.println();
    // if you didn't get a connection to the server:
    Serial.println("connection failed");
  // if there are incoming bytes available
  // from the server, read them and print them:
  if (client.available()) {
    char c = client.read();
    Serial.print(c);
  // if the server's disconnected, stop the client:
  if (!client.available() && !client.connected()) {
    Serial.println("disconnecting.");
    client.stop();
    // do nothing forevermore:
    for (;;)
amirf
#1
Apr 02, 2019, 03:46 am Last Edit: Apr 02, 2019, 03:47 am by amirf
Not sure what the issue was but it was fixed after I used the board a few times. Ther is no option to remove the question!
sandeepmistry
You must remove the following
Code: [Select]
  while (!Serial) {
As it waits for the Serial Monitor to open the IDE.
