Topic: 1-Bit and 24-Bit Integer Variables, Please (Read 2091 times) previous topic - next topic
pert
First, "Arduino" is not a programming language.  It's more of a "framework" based on standard C/C++
I'm very interested in this topic. When I first started with Arduino I though .ino files were written in Arduino language. As I realized how awesome microcontrollers are and made the decision to dive deeper into this world, I started looking at alternatives to Arduino. I felt that learning a proprietary "toy" language would be a waste of my time in the long run, as I reached the limits of what I could do with the language and decided to move on. Then I read that the Arduino language was C++. That was a big "aha!" moment for me, which made me confident that sticking with Arduino was the right decision.
When I've seen people talk about the Arduino language, it's usually done by beginners or people denigrating the Arduino project. I was aware that somewhere on the Arduino site they talk about the Arduino language, but I thought of that as perhaps just an attempt to make things seem less intimidating to a beginner who might just shut down at mention of C++. My belief was further reinforced by a Hackaday article from Elliot Williams, who always writes excellent articles:
https://hackaday.com/2015/07/28/embed-with-elliot-there-is-no-arduino-language/
Over the years, I've corrected people talking about the Arduino language here several times. I've thought that the impression that there is an Arduino language and an "Arduino compiler" was harmful to the learning process and led to misconceptions (perhaps like this discussion).
Recently, I submitted a proposal to Arduino about adding some text about C++ to the Arduino Language Reference pages. I was informed by a couple of very knowledgeable Arduino employees, whose opinions I respect, that .ino files are written in Arduino language, not C++:
https://github.com/arduino/reference-en/issues/476#issuecomment-461491446
I understand the sketch preprocessing process, but I never thought that it made enough of a difference to qualify the code written in .ino files as a new programming language. This made me realize that I have no clue where the line is on what becomes a new programming language. Although I've seen well thought out arguments about why there is no Arduino language, I've never seen one arguing the contrary. It would be interesting to see something like that written by someone knowledgeable on the subject of programming languages.
AWOL
I don't think of it as a new language, more as a pidgin or creole - it isn't exactly C++, but one should just about be able to make oneself understood to a native speaker.
(Among the Koorie people from the Victoria outback in Australia, a solar eclipse is "Kerosene lamp b'long Jesus gone bugger-up". source: The Telegraph)
I don't think it qualifies as a dialect.
BrendaEM
#17
May 20, 2019, 08:06 pm Last Edit: May 20, 2019, 08:17 pm by BrendaEM
The libraries that allow Arduino to cross-compile and load the code are quite and achievement. Dozens of boards use the Arduino's IDE. Because Arduino's language is unique, it is language. It may mostly be C, but that's not all it is.
My purpose in asking for the data types is not only for efficiency, but for readability. It could be said that manual bit packing is clever, but its code is ugly, and distracting from the larger program. A compiler could easily pack, in this case, 8 bits into a byte.
The problem comes with code trans-portability and readability when moving to a processor with a larger word length. If there was an auto-bitpacked variable, the same code would just be more memory efficient because the library/compiler would know the word length.
If 1-bit auto-bit packed variables as well as 24-bit integers were integrated into Arduino's...vocabulary--would you avoid using them, or would you use them?
pert
I wrote a library with some unique functions and typedefs. Did I create a new programming language?
It may mostly be C
There's more C++ than C.
First of all, it's already been explained to you that we have 24 bit variables. Use them if you like. Case closed on that.
As for 1 bit variables, please provide a demonstration of how this should be implemented in Arduino's core library. Remember that we are using a standard C++ compiler. Arduino is not in the business of writing compilers (nor would you want them to be).
westfw
"bool" or "boolean" could be a single bit, except for C's desire to have basic types be pointable-to (and probably promotion issues, too.)   Then it would just work the same way that "bool" works now.
I'm not sure which Arduino library functions would actually need to behave differently for single-bit values, or which ones would benefit from being able to (what good is having a 1-bit variable if it takes a full register to pass to subroutines, and/or extra instructions to extract from RAM/etc?)
It's sort of a shame that none of the big-name compiler/;anguage gurus jumped on ARM's "bit-banding" feature as a way to provide full-featured 1-bit types.  (It seems it's been dropped from the ARM due to lack of interest.)  OTOH, the lack of 1-bit variables in any standard computer language that I know of probably means that it has seven more "problems" than the ones I've mentioned.
BrendaEM
#20
Jul 13, 2019, 10:29 pm Last Edit: Jul 13, 2019, 11:14 pm by BrendaEM
The problem with Booleans is that they very-likely have no automatic bit-packing, so each Boolean likely takes an entire byte, not counting the memory pointer.
I am writing bit-packing into my application, but the result will be sloppy, in that the user will be exposed to the Byte/Bit offsets.
I thought that in a manner vaguely similar to how const's are handled that the IDE could behind-the-scenes, create maintain a table for bytes and bits used, more efficiently and more readable than a person could, because I thought this would be more readable:
bits subscribed, paid up;
if ( subscribed == 1)
// Blink Kiosk Light
// Or perhaps...
bits quadcopter_area_collision_map [12, 12, 8];
// Or perhaps...
bits eepromblockflags[16];
While single-bit auto-bit-packed variables have storage advantages--especially in chips that have only 2k or 4k of RAM.
I think that the user's program will read better by not exposing the reader to saving techniques, in the IDE. This kind of technique can efficiently be done at compile time--especially in a Harvard architecture type micro-controller.
If there are Int24s available, then why not support them? Why not document them?
All the colors on the screen you are seeing are represented by 24 bits, one each of: red, green, and blue.
pert
this kind of technique can efficiently be done at compile time
You keep saying this, yet you refuse to explain how it can be done.
What do you mean by "supported"? You can use them; what more support do you want?
BrendaEM
#22
Jul 14, 2019, 12:19 am Last Edit: Jul 14, 2019, 12:42 am by BrendaEM
Pert, where exactly did I refuse anything in this thread? You may not know this, but that's likely slander.
I am registered and have used some 82 other forums. Except for trying to share things with people, file bug reports, and offer suggestions, I don't like coming using the Arduino forums. While people may offer differing opinions or methods to accomplish programming goals, I feel that there is an undercurrent here of unchecked cruelness to new would-be programmers. I hope that over time that will change because young, impressionable people also visit these forums--and they don't need that. Anyway....
When and if someone chooses to use a single 1-bit variable, on compile-time, the IDE could initialize a table of: variable name, byte, and bit, likely as pointers, but for the course idea is:
variablename, byte, bit
myvar, 0, 0
In the above example, the byte position would be a relative offset starting address from where the compilers would keeping the bit variables.
The compiler would deal out memory in 8-bit or 16-bit int chunks, whichever is more efficient. A maximum byte-bit tally can be kept, so the next table entry lines up to the last, in a similar manner to a filesystem freespace allocation map. Because it's done at compile time, in a static manner fragmentation is not an issue.
Using a single-bit variable would cost in program memory, in the form of a library loaded behind the scenes. In my experience Arduinos have more practical space issues with RAM than program memory.
The loaded library would include small, efficient compact routines to translate the changes to the variable, And'ing or Or'ing them for the user.
In the case of an bit array, the table could be extended to use a bit length, likely confined to a particular size. The table entry would look could this:
variablename, byte, bit, length
myvar, 0, 0, 32, 16
Without the compile-time bit locations, the user would either have to use global variables for it's housekeeping, (which doesn't personally bother me, because I am working on my projects alone, and I enjoy organizing namespaces and structures) or they need to lean toward creating an object-oriented approach, which I feel is too abstracted for efficient micro-controller programming.
pert
I asked you two months ago:
I interpret no response to that request after such a long time to be a refusal. If you think that's slander, go right ahead and sue me.
I'm glad you're now providing some details of your proposal, but I still don't understand how it would work. You mention a library, which is great, but I don't see how 1 bit variables can be accomplished by a library alone. Certainly we can use a function or macro to read and write bits of a variable, and Arduino already provides this via the bitRead() and bitWrite() functions. But I don't think that's what you're talking about.
I reject any proposal that has Arduino creating their own compiler, or doing some crazy sketch preprocessing in the Arduino IDE like what they do with function prototypes. If you want to advocate that C++ compiler engineers add a 1 bit type to the existing compilers like GCC, great, but it's very unlikely any of them hang out in the Arduino Forum so I take this as being a proposal directed at the Arduino developers or the Arduino community.
I completely understand why you want a 1 bit type, and I'm very much in support of it if it's possible to do in a feasible, portable, and user-friendly manner.
BrendaEM
#24
Jul 14, 2019, 04:05 am Last Edit: Jul 14, 2019, 04:06 am by BrendaEM
[Pert, I am not expecting your to be a courteous, but it's bad form to write that someone stated something--when they did not.]
Oddly, I am not a big fan of C++ because I feel that burns memory too fast and easily for micro-controller work.
While 1-bit auto-bitpacked variables more complicated than the const's, it wouldn't be rocket science. If you could see why I would want them, then they aren't so crazy after all.
[For a data transmission project, I already have a single-bit flag function that takes an array of bytes that will use global named constants as bit-pointers. For now I am just using enums, but they are costly, being ints. I will be adding another function and another byte array and another bitmap for another series of flags. Though, it occurs to me, that this would be useful if it were implemented in the language, in a generic sense. For my purposes, I can write something a little more generic, though, users don't need to see the mechanisms, and they may want to declare these positions locally.]
It would seem that single-bit variables would carry with them a complex pointer, a pointer that points to a byte and a bit.
bobcousins
Single-bit variables are never going to happen, so you may as well forget about that.
In the rare event you have a lot of bools and want to save space, it is trivial to write a user library to deal with them as a packed array.
Please ask questions in the forum so everyone can benefit. PM me for paid work.
BrendaEM
It's not about sending data through a library, it's about the final readability of the code.
So, if a single-bit bit-packed variable was available in Arduino, you wouldn't use them?
westfw
Quote
You know, probably not.  They cases where I need a bunch of individual bits in quantity enough to impact memory usage (or program readability) are essentially non-existent.
Arrays of bits, sure.  Single bit values as a part of some higher-level structure - those too.  But those are all things that are likely to be abstracted in better ways than having a single-bit basic data type and treating them like I would in a ForTran program...
(These conversations are difficult if you only drive by every couple months to participate...)
BrendaEM
#28
Jul 16, 2019, 09:36 pm Last Edit: Jul 16, 2019, 09:37 pm by BrendaEM
There is another way to look at the one-bit variable. Arduino's Booleans are stored inefficiently, and in an inflexible manner.
I am curious why the 24-bit variables aren't included in the documentation.
In all the forums that I have been to, I have never had anyone complain about my timing, much less two, people in the same thread. Very interesting. I am not having difficulty with my timing.
noobydev
Hm, I can'T see the point here.
I am a "newbie" but I still was capable to "pack" serveral bit in a Byte für Project. Just add 1,2,4...256 to a Byte to increase a Special bit or %2...256 to check for a bit.
Not as complex. And für RGB. Why not handle 3 Byte (red, green, blue)? Put it in a for-statement and it's readable, or?
E.g.:
Byte value;
if (value % 4 = 1)
print("The 3rd bit of value is true");
