Topic: A small problem (Read 583 times) previous topic - next topic
Siffredi
Hello !
I have a small problem with a tension sensor more exactly the Tension Divisor Grove .
I use a Arduino Mega 250 and i have some problems with the connection cables. I wrote the program
and also i use a Laboratory DC POWER SUPPLY to tell the sensor what tension he must read .  But after
i  wrote all the program , i made all the connections ... the only problem si that when i change the value of the PC POWER SUPPLY  the sensor don't change the numbers , i mean if on the DC POWER SUPPLY is 1A and 10V the sensor show me like 1,5V :-? event if i put 0.5A and 5V the sensor keep the same value.
What can i do?
AWOL
Hello !
In English, we rarely use "tension" except for "high tension".
We normally just use "voltage".
J-M-L
Show us your code and your wiring would be a good start...
Hello - Please do not PM me for help,  others will benefit as well if you post your question publicly on the forums.
Bonjour Pas de messages privés SVP, postez dans le forum directement pour que ça profite à tous
