Topic: problem with receiving new data through serial port (Read 170 times) previous topic - next topic
Nidhal
Hello,
I'm using python program to do image processing and calculating the degrees that the motors should moves and send these data to the arduino and it works. However the data is not changing , the motors keep moving to the first location. I was using arduino uno and I tried to restart the arduino at the end of the loop by pushing the switch '' I know that I can use the REST pin to restart it but I was just checking'' and it works fine, I got the new data by restarting the arduino
Now I'm using arduino mega  and If i push the switch to rest the arduino it stop moving '' it's not getting any data'' until I restart the python program then it received the new data and star working.
why I'm not getting the same results as arduino uno .. I can't restarting python program because it takes some time to run and it should not work like that
any idea to get the new data ?
here is my arduino and python code
Code: [Select]
import cv2
import numpy as np
from numpy import *
import serial
import struct
import time
ARM_Y_MAX = 350
ARM_X_MAX = 700
RESCALE_FACTOR = 0.5
cap = cv2.VideoCapture(1)
cap.set(3, int(1280*RESCALE_FACTOR))
cap.set(4, int(720*RESCALE_FACTOR))
for i in range(15):
    _, frame = cap.read()
#r = cv2.selectROI(frame)
arduino = serial.Serial('COM8', 9600)
time.sleep(2)
while 1:
    img_crop = frame[int(50):int(50+239), int(78):int(78+478)]
    hsv = cv2.cvtColor(img_crop, cv2.COLOR_BGR2HSV)
    lower_red = np.array([0, 80, 50])
    upper_red = np.array([30, 255, 255])
    mask = cv2.inRange(hsv, lower_red, upper_red)
    res = cv2.bitwise_and(img_crop, img_crop, mask = mask)
    blur = cv2.GaussianBlur(res, (15, 15), 0)
    cv2.imshow('Gaussian Blurring', blur)
    _, puck = cv2.threshold(blur, 70, 255, cv2.THRESH_BINARY)
    cv2.imshow('Puck', puck)
    cv2.imshow('frame', frame)
    xs = np.where(puck != 0)[1]
    ys = np.where(puck != 0)[0]
    xstd = np.std(xs)
    ystd = np.std(ys)
    x_init_avg = np.mean(xs)
    y_init_avg = np.mean(ys)
    # possibly if std is too high, we can consider that we have a problem?
    xs = [x for x in xs if x <= x_init_avg+xstd or x >= x_init_avg-xstd]
    ys = [y for y in ys if y <= y_init_avg+xstd or y >= y_init_avg-xstd]
    xavg = np.mean(xs)
    yavg = np.mean(ys)
    cropped_height, cropped_width, channels = img_crop.shape
    puck_x = xavg/cropped_width*100
    puck_y = yavg/cropped_height*100
    desired_arm_x = ((puck_x/100.0)*(ARM_X_MAX*2))-ARM_X_MAX
    desired_arm_y = ARM_Y_MAX*2 - ((puck_y/100.0)*(ARM_Y_MAX*2))
    px = desired_arm_x
    py = desired_arm_y
    z=180
    a1= 250-z
    a2 = 320
    a3 = 400
    theta1 = arctan(px/py)
    theta1 = rad2deg(theta1)
    r1=sqrt(px**2 + py**2)
    r2=sqrt(r1**2 + a1**2)
    phi1=arctan(r1/a1)
    phi2=arccos((a2**2+r2**2-a3**2)/(2*r2*a2))
    theta2= pi - (phi1 - phi2)
    phi3=arccos((a2**2+a3**2-r2**2)/(2*a2*a3))
    theta3= (pi- phi3)
    theta2 = rad2deg(theta2)
    theta3 = rad2deg(theta3)
    if theta1 > 0 :
       theta1 = int(theta1)
       d=0
    if theta1 < 0 :
       theta1 = int(abs(theta1))
       d=1
    if 255 > theta2 > 0 :
       arduino.write(struct.pack('>BBBB',d,theta1,int(theta2),int(theta3)))
       print('theta_1: ', theta1)
       print('theta_2: ', theta2)
       print('theta_3: ', theta3)
    k = cv2.waitKey(5) & 0xFF
    if k == 27:
        break
Thank you
Nidhal
Arduino code
Code: [Select]
// Include the Servo library
#include <Servo.h>
#include <EEPROM.h>
// defines pins numbers
const int step1 = 21;
const int dir1 = 20;
const int en1 = 19;
const int step2 = 17;
const int dir2 = 16;
const int en2 = 15;
const int step3 = 2;
const int dir3 = 3;
const int en3 = 4;
const int step4 = 8;
const int dir4 = 9;
const int en4 = 10;
// Declare the Servo pin
int servo1 = 22;
int servo2 = 24;
int servo3 = 26;
int servo4 = 28;
int servo5 = 30;
// Create a servo object
Servo Servo1;
Servo Servo2;
Servo Servo3;
Servo Servo4;
Servo Servo5;
int incoming[3];
int direct1;
int theta1;
int theta2;
int theta3;
int mov1;
int theta1box=40;
int theta2box=105;
int theta3box=30;
int H2;
  // Sets the two pins as Outputs
  pinMode(step1,OUTPUT);
  pinMode(dir1,OUTPUT);
  pinMode(en1,OUTPUT);
  pinMode(step2,OUTPUT);
  pinMode(dir2,OUTPUT);
  pinMode(en2,OUTPUT);
  pinMode(step3,OUTPUT);
  pinMode(dir3,OUTPUT);
  pinMode(en3,OUTPUT);
  pinMode(step4,OUTPUT);
  pinMode(dir4,OUTPUT);
  pinMode(en4,OUTPUT);
  digitalWrite(en1,LOW);
  digitalWrite(en2,LOW);
  digitalWrite(en3,LOW);
  digitalWrite(en4,LOW);
   // We need to attach the servo to the used pin number
   Servo1.attach(servo1);
   Servo2.attach(servo2);
   Servo3.attach(servo3);
   Servo4.attach(servo4);
   Servo5.attach(servo5);
   Servo1.write(60);
   Servo2.write(180);
   Servo3.write(180);
   Servo4.write(180);
   Servo5.write(0);
    if (Serial.available() >= 4){
    // fill array
    for (int i = 0; i < 4; i++){             // 2= number of values receved at the end it should be 6
      incoming[i] = Serial.read();
    // use the values
    direct1= incoming[0];
    theta1= incoming[1];
    theta2= incoming[2];
    theta3= incoming[3];
    MoveToObject();
    GrapObject();
    delay(200);
    PutObject();
    reference();
    theta1=0;
    theta2=0;
    theta3=0;
    incoming[0] = 0 ;
    incoming[1] = 0 ;
    incoming[2] = 0 ;
    incoming[3] = 0 ;
void MoveToObject(){
     if ( direct1 == 0){
       digitalWrite(dir1,LOW);
      if ( direct1 == 1){
       digitalWrite(dir1,HIGH);
       theta1=abs(theta1);
        for(unsigned long x = 0; x < theta1*525L; x++) {
        digitalWrite(step1,HIGH);
        delayMicroseconds(70);
        digitalWrite(step1,LOW);
      digitalWrite(dir4,HIGH);
      for(unsigned long x = 0; x < theta3*2000L; x++) {
        digitalWrite(step4,HIGH);
        delayMicroseconds(20);
        digitalWrite(step4,LOW);
      digitalWrite(dir2,HIGH);
      for(unsigned long x = 0; x < theta2*2350L; x++) {
        digitalWrite(step2,HIGH);
        digitalWrite(step2,LOW);
void GrapObject(){
  // Close fingers, then.....
   Servo1.write(180);
   Servo2.write(0);
   Servo3.write(0);
   Servo4.write(0);
   Servo5.write(180);
H2=40;
          digitalWrite(dir2,LOW);
      for(unsigned long x = 0; x < H2*2450L; x++) {
        digitalWrite(dir3,HIGH);
      for(unsigned long x = 0; x < 90*2000L; x++) {
        digitalWrite(step3,HIGH);
        delayMicroseconds(18);
        digitalWrite(step3,LOW);
void PutObject(){
if  (direct1 == 1){
  theta1= -theta1;
   theta1 = theta1box - theta1;
   theta2 = theta2box - (theta2 - H2);
   theta3 = theta3box - theta3;
        if ( theta1 > 0){
      if ( theta1 < 0){
       theta1=abs(theta1);
        if ( theta2 > 0){
      if ( theta2 < 0){
       theta2=abs(theta2);
          if ( theta3 > 0){
      if ( theta3 < 0){
       digitalWrite(dir4,LOW);
       theta3=abs(theta3);
          digitalWrite(dir3,LOW);
    // open fingers
   Servo1.write(60);
   Servo2.write(180);
   Servo3.write(180);
   Servo4.write(180);
   Servo5.write(0);
void reference(){
        for(unsigned long x = 0; x < theta2box*2750L; x++) {
          for(unsigned long x = 0; x < theta3box*2000L; x++) {
          for(unsigned long x = 0; x < theta1box*525L; x++) {
Robin2
Don't Double Post, I already responded to your other Thread.
As there is no new info here I am suggesting to the Moderator to lock this Thread.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
